I picked up a '94 that I want to go through. I've got some of the critical parts like :
Alto clutches & steels, Steel OD sun gear, Alto Intermediate shaft, Heavy duty bands, etc...~ $900 worth
Nothing exotic, this is not going to be a drag truck, but I will be doing some towing and I've already turned up my ip plus other mild mods.
One thing - it came with a 4x4 tailshaft so the existing one will have to be swapped over. I've got the '94 engine adapter plate and starter and some other odds end ends.
I'm looking to learn - and work on - the tranny. More important I'm looking to get a good job at a low cost. It took me 5 mos to get these pieces together. Being retired sucks!
'93 D250 CC auto, 18.5cm w/30 psi - 32 psi w/TC locked, 366 spring w/1 turn clipped, power screw bottomed - backed off 1 turn, modified Ol Smokey's power pin, smoke screw fully out, hat modified to get pin higher - still smokes, '94 trans w/clutches and some hard parts, 4510 w/4 1/2" intake and heat shield, grid htrs mia, 4" dp into 5" pipe to single 5" stack, 285's rear 265's front
