I had to use a chisel when I changed gears, couldnt break the bearings loose with the socket method, just bent a couple brackets on the axle.
02.5 2500 4X4 reg cab white HO 6spd
Tapped Edge Comp with TST plate and Bosch RV 275 sticks.
Stacks by Hogg innovations to roll the coal...
Hogg innovations lift pump/filter big line setup,
Multi function shifter stick,Solenoid High Idle
LED's all over, and CF stickers too!!
