the v8 nv4500 has a smaller main shaft.. The v-10 and diesel ahve a 29 spline main shaft and the v8 has the 23 spline.. The advantage is you can use a t case from an auto truck with a v-8 nv 4500 but you have the smaller main shaft.. Go to
NV4500 Transmissions - Adapters - NV4500 Conversion Kits | NV4500.COM and they have all the info you would ever need.
1998 12v CTD 2500 club cab short box maroon 4x4 auto 3.53 True Flow filter Kdp killed auto meter pro lite boost egt trans temp oil press hillbilly 4" exhaust muff cat ring mia #10 plate centered boost elbow. Got R Did
