Originally Posted by chrigu
i need now the fuel unit for higher levels or not?
i have walbro lift pump installed with big line kit.
chris
no you don't need it....the ADR will run just as hard with it as with out it
but again i would run a gage just for a piece of mind and to keep an eye on the F/P...you want to keep it between 10-16psi at all times
2001 4X4 Q-cab Sport black, full billet DTT trans, billet F-plate Mach 7's, B1-B2 twins, Blue Chip Special X VP, Adrenaline, studded & O-ringed, BD-RAD,Flex-A-Lite electric fans, Autometer Gages, Egt, Boost,Fuel, Oil &,drive pressure, trans temp, RASP, Big line kit, Track bars 2" leveling kit, 271 T-case, DSS, 3rd gen trac bar 623 HP 1175tq with old set-up
