Originally Posted by buzzard
I do pull heavy (22k) trailers when I tow but That may be 10-15% of the time. The rest is city/hwy driving and the occasional shot down the local 1/8th mile track. What do you think Ill need to be able to handle this with 400-450 h.p.?
Your 48RE transmission is much better internally than the old 47RE was. It can handle the 450HP no problem with a simple Valve Body and Torque Convertor upgrade. The BD Valve Body will increase the clutch apply pressure to insure the clutches will not slip and create a much better shift. The stock convertor is just plain and simply junk, its too loose, a BD Low Stall, Multi-Disk Convertor prevent slippage. The lower stall convertor will put you back in the peak torque range of the engine and will result in more power transferred to the rear tires and better fuel economy while city driving in stop a go traffic.
Hope this helps
03 Dodge Ram 2500 2WD Reg Cab
BD X-Tuner stacked with BD X-Power
BD Super-B Turbo & Dual X-Hale Exhaust
BD Max Flow Lift Pump
Ice Box Cold Air Intake
Toll Free 800-887-5030 ext 105 Dave
www.dieselperformance.com
dave@bd-power.com
