Old 07-02-2008, 05:54 PM   #12 (permalink)
jcarl735
jcarl735's Avatar
Originally Posted by mondtster View Post
Wrong, that's the way the truck is supposed to work. When OD is locked out, your converter will lock up, but if you hit the button again to enable OD the converter is supposed to unlock, then the transmission will shift and the converter will lock up again.
That's not a smart idea unless you have a billet input shaft. Hence the reason that the factory controller unlocks the converter in the condition you described above.
oops on the first part! sorry about that. anywho i do have billet shafts in the trans. still probably not a good idea to shift when locked up huh? well anyway can you lock up the convertor in 2nd as well as 3rd and 4th?
3.55s, 305/70/16s, MBRP 4''Turbo Back, #100 Full Forward, AFE ProDry Stage 1, DDP3s, Boost Elbow, AFC !MIA Silencer Ring !MIA, 55 PSI, DiPricol Boost/Pyro/Trans, KDP Tabbed, Built 47re, Farmboys Full Cut DVs, 3k GSK, ATS Quikspool
jcarl735 is offline   Reply With Quote
