Originally Posted by jspike91
ok, not to high jack the thread, but mine is doing the exact opposite, if i take off from a stop, it almost immediately shifts through every gear, then when i am coming to a stop, it wont downshift on its own. I can shift it manually and it does fine, however when downshifting manually, i take off the overdrive and it will not kick back into drive, but when i get slow enough to pull it into 2nd, it will kick back, then i have to manually get it back into 1st.. any ideas???
97 3500 4x4. 91K miles...
Are you absolutely sure you are really taking off from a dead stop in OD (or any gear other than 1st for that matter)? It is normal for torqueflites to remain in 3rd (direct) until you are almost completely stopped and then it will drop to 1st. Taking off from low speeds will always suck unless you pull it into second.
It is also not necessarily uncommon for the electronically controlled torqueflites to make a second gear start since that is the default "limp home" gear for them to be in. It could be a sign of forthcoming issues and/or possibly a bad pressure transducer or governor solenoid.
