Originally Posted by Dual K20s
No
If you think about the 4 cycles in our engine you'll realize that it would take almost 180* of crankshaft rotation for the piston to contact an intake valve that stayed open to long. The stockers aren't that bad
Although if you have the money and are doing the exhaust you might as well do the intake to get a new set of springs and be able to keep them closed tight for high boost. But like I say its not a necessity
Haha, but think of it in another way...
Once you experience valve float, even if the valve stays open for a fraction of a second thats enough to have the piston smack it!
@ 4000rpm each piston passes TDC 66 times a second, depending on the piston-valve clearances its pretty easy to smack a valve!
These diesels can be much worse than a gasser since they run not even 1/4 of the spring pressure!
97 Ram 2500 / 5.9ctd / 5spd / nv4500 / 4x4 / np241
Starwheel cranked, no plate, autometer pyro and boost gauges, Single 4" stack, 33x10.5 Mud terrains, tons more to come
