Originally Posted by Russ Roth
Good write up. You can buy (5 for a buck, I think) 33 ohm resistors @ Radio Shack and put that in the ground line from the switch. You can leave the relay in and not set codes or have the tranny go into limp mode. Personally, I would not want my TC to unlock when I put on the brakes because you would lose the increase in compression braking that comes with having the switch engaged. I absolutely hated that from the first time I drove this rig.
I have also started hitting the switch the minute I start moving. It locks and causes the trans to stack the shifts into third. I hit third about 20 MPH and it seems to have increased my in town mileage about a mile to the gallon.
Just be careful. Locked shifts aren't nice on stock transmission shafts.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: turbo and bigger exhaust, both seriously needed now!
