Old 06-23-2008, 11:56 PM   #2 (permalink)
mondtster
Try running through the gears manually to see if it shifts at all or not. If it does shift manually, you might be able to get away with just flushing the tranny and cleaning the valve body up. With what you're describing however, I would plan for the worst and hopefully you will be surprised.
mondtster is offline   Reply With Quote
