Old 06-23-2008, 09:56 PM   #17 (permalink)
JacktheBear3
FTE Diesel
JacktheBear3's Avatar
Originally Posted by SnowFoxDH View Post
Wally. Thanks for the PM. This may sound foolish, but was just a thought. Do you suggest mounting the Hushpower Pro where the old muffler used to be or where the old cat use to be? I didn't know what performance loss or drone control improvement you might see from mounting under the cab.
Most all of our actual installs have been on trucks that have been straight piped or aftermarket exhaust that used a performance muffler. Every customer had a DRONE issue at highway speed, so our placement of the muffler varied depending on what our situation. The drone was gone and the noise in the cab was minimized by half.... But the truck still sounded ROCK SOLID.
Depending on the situation, you can put the muffler anywhere you can fit it.... we tend to put it near the OEM Muffler spot so we can take advantage of the hangers to support it. The muffler is not very heavy, but it is good practice to support it.
2002 24V, 2500 Quad Cab, Dark Silver, We Bit O Lift, Plain Jane, Comp (drag), BDRAD, Smarty Stack, 027 SO VP, FASS 150/150 w/BigStraw, F1 Mach 7.?, The Girlz are T61 & S400, PDR Stg III Head w/Rings top & bottom, HTS/FTE FULL billet Auto, SS Single Converter, Optix Gauges ( all high #'s), Detroit Locker, Custom 6" Miters, and plenty O junk in the Trunk...
Floor It CP3 MOD's & PPE Dual Fueler Kits
6.7 Race / Delete Pipes and Sims in stock
JacktheBear3 is offline   Reply With Quote
