Old 06-23-2008, 09:44 AM   #17 (permalink)
Diesel-Dan
FASS Tech Dept.
Diesel-Dan's Avatar
Originally Posted by DART505 View Post
Well used high pressure to backflush the siphon tube and still no luck.If you have it in neutral with the box on #3 stick it to the floor real quick & let off 10 psi is what it drops to.
Have you tried the 5 gallon bucket test yet or sucking out of a jar of fuel?
If your suciton tube has a crack in it....blowing air back in the line will not do anything for you.....
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
Diesel-Dan is offline   Reply With Quote
