Thread: EGR delete
Old 06-22-2008, 03:36 PM   #10 (permalink)
IdleUp
IdleUp's Avatar
Originally Posted by BroncoHound View Post
Hey Mike,
The active regen occurs when the DPF fills to a specified level. the general concensus is that this usually happens about every 400-500 miles depending on all the typical variables (load, speed, city vs. highway, big tires, etc etc etc).
When the truck goes into an active regen the EGT's will raise which is your best indication that the regen is occuring. Some have also made note of a unique smell coming from the exhaust while in regen though I myself have never noticed such a thing. Another way to tell is to watch your EVIC fuel economy readout. If you see your mileage start dropping for no apparent reason, you are likely in active regen.
There is a module that fools the ECM into believing the DPF is still present and functioning properly with a DPF delete kit. This module typically taps into the sensors plugged into the DPF and mounts to the inside of the frame so it is out of the way and still within reach of the exhaust sensors. Hope this helps.
Thanks for the reply - I just crawled around the bottom of the truck and aside from the sensors in that area, I also noticed some steel lines (before and after the filter) that run to both sides of the exhaust. Any idea what they do?
Thanks
Mike
2008 3500 Resistol 6.7 Bone Stock
www.bigpickup.com
www.rotory.com
IdleUp is offline   Reply With Quote
