Originally Posted by DART505
Pump is 6 months old,I do not have the SN handy. I think I will blow back the siphon to see if it's strainer is partially restricted.Where is the bypass located in this pump?
Its internal and not servicable unless you cut the wire. This is not really an issue unless you got real crazy with the teflon tape or didnt use our prestrainer. That is about the only time I see issue with debris that causes pressure probs.
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
