Old 05-23-2008, 01:23 PM   #7 (permalink)
cumminspower01
cumminspower01's Avatar
need help with 2 problems. problem number 1 is when driving down the interstate going home, well i get there and i see fluid running down my front wheel and there was axle grease coming out the vent tube for the axle. whats wrong. problme number 2 getting some blow by out the blow by tube. what could be causing this problem? motor was just rebuilt and has brand new pistons and rings and cylider walls where cleaned up. or is it to much crank case pressure? can anyone help?
97 2500 ctd regular cab, 5in exaust, timing 22*, injectors, no plate, .120 fuel lines, head studs, ringed block,HD valve springs, cam and dd clutch
cumminspower01 is offline   Reply With Quote
