Old 05-22-2008, 08:41 PM   #3 (permalink)
m_reynolds
m_reynolds's Avatar
Well I need pretty much everything that scomes with the system besides the fass fuel pump, filters, fuel lines, and such....
I need:
*fuel pump bracket -- BR-2001
*¼ “mounting bolts -- (2 – 1” & 3 – 1 ½”)
*3/8“mounting bolt and flanged nut -- -- 6 ea.
*Frame Bracket (“L” Shaped) (dim. 9.5” x 4.3” x 3”) 1 -- FB-1001
*Washer (Thickness 3/16”) -- -- 2 -- WA-1001A &
*Washer (Thickness 11/16”) -- -- 3 -- WA-1001B
I need everything that is necassary just to "mount" the pump. Should all of the things that I have listed cover that??
Also, will james at rollin smoke diesel have access to get all of these parts or will I have to go another route??
2001 2500 Ext. Cab 4X4 6spd HO, EDGE COMP, FASS 150/150, HTT Exhaust Manifold, ISSPRO Gauges (FP, boost, pyro), Silencer Ring=GONE, Special Thanks to James at Rollin Smoke Diesel....
m_reynolds is offline   Reply With Quote
