Originally Posted by m_reynolds
Dan,
I am not realy for sure if I need one or not at the time, but I was going to check with you and ask you if there would be any way that I could just get me the mounting kit for a 150/150 fass pump for my truck. I asked James at Rollin Smoke Diesel and he said that he couldn't find a part number or somthin like that and told me that I should refer back to you about the situation and then get back with him. The situation is this: The guy that put mine on for me fabricated my brackets and stuff and the dang filters hang way down below the freakin truck and that aggravates the heck out of me. It's like they're just sittin there waiting to be ripped off by something. Also, if the fass is installed correctly with the mounting kit, how much do you think the filters should hang down??
Well long beds you cant see the pump or filters. Short beds of your year, the filters should just peak out....but should be higher than the frame.
The frame bracket for your truck is:
FB-1001-P
Now if you also need the bracket that bolts to the FASS the one we are currently using is:
BR-2001-P
Dan MacDonald
www.FASSRide.com
2001 2500, 4x4, Con OFEed, TBK, AFE Stage II kit W/ prefilter and 4" cowl mod. , FASS 150/150, Mach 2's, Drag Comp,
Currently running on B-100
'02 Jetta TDI 5 Speed "Mini Me" 45-50 MPG
