Old 05-20-2008, 11:40 AM   #15 (permalink)
94cummins4x4
94cummins4x4's Avatar
dont worry, i dont think the ez has enough fuel to smoke a stock tranny unless its on its way out. I just put mine on and left the map unplugged and its fun but not enough. im goona put a set of either 150 or 100 hp sticks in to match the timing they put in with some more fuel. Then go from there. Im putting a transgo shiftkit in at the same time as the injectors as well. Leaving the map unplugged will give you better throttle response and a little bit more smoke. I will be pluggin it back in when i get the sticks
94 2500 4x4: 10 plate, 3" lift and some trimming and 38.5 hawgs more comming soon
94cummins4x4 is offline   Reply With Quote
