Old 05-20-2008, 11:20 AM   #14 (permalink)
JeepHauler
Originally Posted by DIESELDALE1 View Post
I May Be A Little Late With This But Let Me Tell You About The Ez I Have On My Truck. It Is Set On 5. They Must Set Them By Taking The Back Plate Off And Setting The Jumper Where You Want It. I Was Hotshotting. When Pulling A 16000 Lb Load On My 16000 Lbs Of Truck And Trailer Mileage Went From 6.3 To 7.8 Mpg. It Would Stay In Overdrive And Lockup. That Was The Good News. The Bad News- I Have An Automatic. I Burned The Tranny Out Twice And Sheared Off The Bolts On The Torque Converter. Wiped Them Both Out.
I Have Quit Hotshotting But Left The Ez On The Truck. I Have A Sfi Flexplate, A Ptc Triple Disk Torque Converter, Better Disks, And Valve Body. Ptc In Muscle Shoals Built It For Me. I Also Changed The Trans Cooler To 2 10"x 15" S Flow And A 30" Finned Cooler. It Stays Real Cool In Od When Going Fast. 75mph. It Warms Up In Town. Right Now I'm Looking For A Lockup Switch That I'm Comfortable With. I Am Trying To Design It Myself But Having Problems. I Put Guages (pyrometer, Tranns Temp, And Boost) On My Truck. The Temps Stay Low And Boost Is Fine.
I Like The Ez But Either Set It At 1,2, Or 3 Or Plan On Doing Trans Work If Your Loading It Heavy. I Love The Power And Torque. I Seen One On Ebay For $215 Yesterday. They Range From There To $450. The're Easy To Install. I Don't Know About Other Units But To Me It Was Pretty Cheap Hp. Believe It Or Not I Bought Mine Used And Have Had It On There Since '04.
Not what I wanted to hear. I won't be hauling much with it, but when I do I guess I need to take it EZ.
Those guys at PTC are great. They built me a custom lowstall converter for my old jeep and it was badddd. You could drop it in low gear and it would lock up all 4 tires.
BTW, I bought a used on off of the boards here also. I should have it by the end of the week.
2001 Quad Cab 2500 4x4 Auto---Bone Stock with 230,000 on it.
NO CARPET, NO POWER WINDOWS, NO POWER LOCKS, NO CRUISE CONTROL, JUST THE DRIVER.
JeepHauler is offline   Reply With Quote
