Originally Posted by Quadman
I know of several people that are doing this now. My freind that is doing this told me that if you use used motor oil, it is broken down and diluted a little from the fuel getting past the rings enough that you can just mix it in with regular deisel fuel. He started with a 30 percent mix. In the summer months he runs 70 percent. His truck does not some too bad bud it does smell like buring oil. he has a filter set up he uses to filter the used oil. I have started doing the same, when i change the oil in my truck or cars i just pour the waste in my tank. I have not been able to tell a difference at all. I have a new truck with the particalate filter. you are not suposed to do it with those but it has made no difference.
No kidding huh? do you make it like you would make biodiesel? What other addatives are you adding to break it down? I hear Cetane and something else are a must.
94 f350 w/ 95 6bt. 370 Hp Marine Injectors, #4 fuel plate, dodgezilla hybrid turbo 14cm wastegated, and a lot more!
