Old 05-09-2008, 07:39 AM   #6 (permalink)
Diesel-Dan
Originally Posted by dbarker4322 View Post
Dan, thanks for the reply.
I have the HPFP. I no longer believe that my pump is the problem, the pressure is good and it is turning on like it should. I can get it running on ether(I know its bad) and even that takes some doing. I believe that the problem is electronic. It sounds like the fuel shutoff isn't letting it start. I'm probably in the wrong section to post, but I do appreciate your help.
DUDE.....go easy on the happy gas....
At this point....check for codes....Injection pumps can die like you are seeing....hate to say that...but i have seen one or 2 go that way. Bad thing is when they die like this, they normaly dont pop a code. SO....might be trickey to pull the trigger on.....
ALSO...check you Batt's. Make sure they are 12V and have high amps load tested! (One at a time)
Diesel-Dan is offline
