Dan, thanks for the reply.
I have the HPFP. I no longer believe that my pump is the problem, the pressure is good and it is turning on like it should. I can get it running on ether(I know its bad) and even that takes some doing. I believe that the problem is electronic. It sounds like the fuel shutoff isn't letting it start. I'm probably in the wrong section to post, but I do appreciate your help.
02 Dodge 3500 Fass HPFP propane
