Originally Posted by Dad
Another good diagnostic for this type of issue is an infrared temp gun. You can get the temp of the exhaust at each port to see if one is cool.
High EGT's, low MPG's and 20 PSI of boost, assuming you have stock injectors, makes me wonder about the MAP sensor. Is the smoke level normal?
No, smoke is excessive. Would the MAP sensor cause an odd sound? Seems like maybe and overfueling issue would though.
It's very rythmic so i'm thinking it's concentrated in one cylinder, which is also why I thought it was an injector.
Tow rig/DD: '03 2500 CTD QCSB 6spd blacked out and slowly retiring itself from stock trim just like everything else I own.
