sounds injectorish - crack one fuel line at a time to see which hole(s) is the prob. Then pull the inj. and see if you see anything wrong (missing tip). And if your oil level is over full you may have one dribbling. Just watch it closely, over fueling can do some bad bad things -
-good luck
96 1ton 4wd duely 12 valve 5 speed - turned the wheel, slid the plate custom 4'' exhaust, other than that its stock
