Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 10-27-2008, 10:17 PM   #1 (permalink)
Banned
Thumbs up Unplugging your EGR RECAP!
RECAP
1. Pulling the plug on the EGR will cause better mileage and fewer regens. General concesnsis is 2 MPG improvement.
2. It will not harm the components down stream. It will actually help them
3. It will generate a check engine light because the computer sees pieces of hardware missing. You will have to deal with it until a code free EGR solution is found.
4. Just unplugging the EGR will not allow soot to build up. Experiments after 6000 miles showed the exhaust pressure is enough to allow the exhaust pressure to bleed off the soot and condensation.
5. This is reversible and will leave a code stored in the ECM. The dealer may or may not see it. Depends on how thourgh he is. This means you can unplug the EGR and go to the dealer with it plugged back in.
6. Some earlier trucks act strange in the beginning. If this continues, you'll need to remove the flapper valve in the intake, or get a later update on the ECM.
7. Unplugging the EGR with a DPF delete has some short term effects on your truck. The two systems are tied together but work independantly. If the problems persist, then you have other problems which we will try to help you with.
8. DO NOT keep plugging in and unplugging the EGR. It confuses the ECM
9. Codes usually generated- P0405 and a low pressure code.
[10. Codes can be cleared with an Edge or a PMT. Some have had good luck with running with the codes cleared and some have not. It's possible the flash level is the problem. Clear the codes before you start and see how it
11. Best Minimum Flash levels.
2008 Standard 62350230AP
2008 Auto 62350235AQ
2007 C&C Stan 52300230AV
2007 C&C Auto 52300234AV
2007 Standard 55350230AY
2007 Auto 55350235AY
DO NOT DELETE THE CODES IF YOU CAN. Your fuel economy can be effected and it could throw your truck into a limp mode when changing climates. Temperature plays a major part in this.
Polaraco is offline
The Following User Says Thank You to Polaraco For This Useful Post:
BuckStrickland (07-09-2009)
Old 10-27-2008, 10:19 PM   #2 (permalink)
cowpunch's Avatar
Is that engine on a truck? Man that sukka is clean!
07 3500 4X4 DRW G56-South Bend Clutch-MP8-Smarty-Industrial Injection super phat shaft 66/80 turbo-Industrial Injection Stage 2 CP3-ARP 425's-ATS pulse flow manifold-DDP 80hp injectors-PPE rail plug-BMK25 Bypass-Isspro EV2 Gauges-Edge Insight-4" TBE 7" Tip-Air Dog DF165-180 Thermostat-Wicked coolant bypass-KMC Rockstars-Debadged
Dynoed 603 hp 1201 ft/lbs
cowpunch is offline
Old 10-27-2008, 11:13 PM   #3 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
Polaraco do you still have all that stuff under your hood or did you do the EGR cooler delete and EGR delete to clean up and lighten under the hood?
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
SkinInc69 is offline
Old 10-27-2008, 11:42 PM   #4 (permalink)
TECH SPECIALIST
DodgeCummins98's Avatar
I'm confused. I didn't know you could just unplug it. I thought you had to block it off. As it sits right now my truck is completely stock like it left the lot. Can I unplug it right now with no ill effects? I have a dpf delete but I've never had the time to put it on. Will I need to plug it back up after doing that?
98.5 2500 4x4 Reg Cab, 6" GrandRock's, Adrenaline w/ Pulse, FASS 150, Isspro gauges, Auto to NV4500 swap, Leveled on 315's Cooper ST's - Engine being rebuilt
07.5 3500 6.7L G56 Manual 4x4 Quad Cab Dually
DodgeCummins98 is offline
Old 10-27-2008, 11:45 PM   #5 (permalink)
08 Cummins
As long as you have the current flash. If you unplug it and it starts and runs fine then your ok. If it runs funny after you start it plug it back in and go get the truck flashed.
08 2500 4x4 6.7 QC HEY WHO KEEPS MESSING WITH MY SIGNATURE??????????????
sking is offline
Old 10-28-2008, 12:19 AM   #6 (permalink)
benzino909's Avatar
schweet recap.
08 - 6.7 - 6spd - Blk: Tint, Shave & LineX. PMT, MP-8, AFE Stg 2, 5" H&S, BMF 20's, 33's, Leveled, SB DxD 3250, EGR Block, DiPricols, FPE Boost Controller. AD150 & Recons waiting to be installed
benzino909 is offline
Old 10-28-2008, 02:21 AM   #7 (permalink)
Thanks for the recap, you just saved someone *hours* of reading
2007 Megacab 6.7L 4x4
hatchy is offline
Old 10-28-2008, 03:05 AM   #8 (permalink)
futuresmoker's Avatar
im one of the someones.. hahaha
thanks a bunch
-Andy- 2003 Chevy Cavalier. 13,400lbs
Originally Posted by SmokinTheHippies wat is the weight a girl has to be before shes too fat to sleep with???
futuresmoker is offline
Old 10-28-2008, 03:07 AM   #9 (permalink)
903 wrecking crew
Dodgeram082500's Avatar
mine was fine so went out and drove it acted a lil strange though when it came down to idle (idled rough) on a hard run so i plugged it back in
2008 dodge ram 2500HD blacktec reg. cab SXT 4x4 6.7 cummins with Smarty S67 ,quadzilla boost fooler (also pulled off),SB 3250dd ,mp-8 thanks to chris (witch is disconnected for now) ,and delete kit intake baffle removed. 432hp VER1017F with pmt
Loving the XRT 476hp 865tq with xrt mp8 stack, 460hp 865tq with smarty mp8 stack.
THANK YOU TO CHRIS AT HDR DIESEL.
www.hdrdiesel.com
Dodgeram082500 is offline
Old 10-28-2008, 05:07 AM   #10 (permalink)
bushhawg's Avatar
Good post
This is a really informative and helpful post. Would make a good sticky. Answers all my questions without all the required reading. Good job!:thumbsup
2007.5 DODGE RAM 3500. FOUR DOOR 4X4 6.7 CUMMINS. 6 SPEED MANUAL. LEVELING KIT. AFE INTAKE. XRT, 5 INCH TBE, AND QUAD BOOST FOOLER.
bushhawg is offline
Old 10-28-2008, 09:53 AM   #11 (permalink)
2rowdy's Avatar
I would suggest now locking this thread.
2007.5, 6.7, brilliant black crystal pearl, ISSPRO rail pressure, boost, trans temp. Edge j/a,w/hot unplugged. Diablo extreme power puck 0%,SMARTY , FS-2500.
448 hp 966 tq Big thanks to techcummins and BEERPLAY.
2rowdy is offline
Old 10-28-2008, 10:23 AM   #12 (permalink)
Banned
Guys
Take the Q & A's and comments over here
Unplugging EGR
Polaraco is offline
