Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 10-05-2008, 10:26 AM   #1 (permalink)
Resetting The OHC Information
Guys,
Here is something you can copy and print and stick in the glove box or in the back of your owners manual so as to be easy to find to know how to reset the OHC when needed.
Got this right from the manual and this might be something to make a sticky up top.
We could even add to this for other issues that come up that just need reset or cleared.
Up to you guys, just thought I would share the info here for whom ever wants or needs.
Oil Change Indicator System
Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Required” on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your personal driving style. Driving styles such as frequent stop and go type driving can increase the frequency of the engine oil change. This is the result of more frequent regeneration of the exhaust aftertreatment system, which can decrease the life of the engine oil. Failure to change the engine oil per the maintenance schedule can result in internal engine damage.
For information on resetting the Oil Change Indicator message, refer to “Oil Change Required – If Equipped,” under “Personal Settings (Customer Programmable Features)'” in the “Electronic Vehicle Information Center (EVIC)” Section of this manual.
OIL CHANGE INDICATOR - RESET
To reset the “Oil Change Required” indicator (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the ON position (Do not start engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Oil Change Required” indicator did not reset. If necessary repeat this procedure.
Perform Service Indicator
Your vehicle will require emissions maintenance at a set interval. To help remind you when this maintenance is due, the Electronic Vehicle Information Center (EVIC) will display “Perform Service”. When the “Perform Service” message is displayed on the EVIC it is necessary to have the emissions maintenance performed. Emissions maintenance includes replacing the Closed Crankcase Ventilation (CCV) filter element, cleaning or replacement of the EGR Cooler, and cleaning or replacement of the EGR Valve.
See your local authorized dealer to have the “Perform Service” message cleared and reset.
PERFORM SERVICE INDICATOR - RESET
Unless reset the “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure:
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
Khaki-09' Megacab 3500 DRW 4X4;68RFE;3:73's;DPF, EGR & OEM air intake horn all MIA;My own 5" TBE,CoolTube intake w/crankcase revented;Edge-juice w/attitude+Hot;07' intercooler; doubled the OEM Powersteering & Tranny Coolers, Smarty67(ME) Raptor 150 with filter & water seperator. 180 T-stat. Double B&W hitches.ARP Studs. HTT-SS 71/64/16Turbo&Exhaust Manifold.Shaved Head.MHP-TCM
Jeb_H is offline   Reply With Quote
Old 10-05-2008, 10:23 PM   #2 (permalink)
Compcowboy's Avatar
Bump for sticky hopefully
691 Hp 1200+ Tq - 2007 6.7 TWIN TURBO DUAL CP3 2500 Bighorn 4x4 6-spd Manual, 64/71/14 over a S400, Airdog 150, ARP Head Studs, TS MP-8, Airbags with Dual Control Air Comp., H&S Delete & Downpipe, What EGR?, Valair Dual Disk, Amsoil Bmk-11 Bypass, 295/70/R17 Toyos on Walker Evans Wheels,6" Aussies & Hushpower Muffler & DiProcol Gauges & 120HP nozzles (Installed!) Thanks to Wally At FTEDiesel!!!!! PMT is gone, Smarty is Gone!, H&S TO THE RESCUE! Black Maxx on the way.
Compcowboy is offline   Reply With Quote
Old 10-05-2008, 10:30 PM   #3 (permalink)
tramp_line_ape's Avatar
agreed :thumbsup sticky material
07 6.7 cummins, 6 speed, one-ton, electric blue, gauges, afe intake, MP-8/Superchip, 4" BADP TB, egr delete, edge w/attitude
Give him books and give him books, and all he does is eat the pages
I.B.E.W. local 57 America is Union
tramp_line_ape is offline   Reply With Quote
Old 10-06-2008, 12:08 PM   #4 (permalink)
libeachbum's Avatar
good info...printed!!
2007 2500 QC 6.7, 2" level, 35" bfg's, things have started falling off...literally
BEWARE OF BADP/MAXIMUM PERFORMANCE
libeachbum is offline   Reply With Quote
Old 10-06-2008, 08:31 PM   #5 (permalink)
wv/5.9/6.7's Avatar
Correct me if I am wrong but the truck just let's us know when the oil need's change by the milage( every so many miles it comes on). I don't think it monitors the oil. Cause my oil change indicator came on about 10 miles after i changed the oil.
07.5 2500 TRX-4 6-sp manual H&S XRT & 5" TB Exhaust to 6" Black Stack leveling kit 315-75-17 procomp extreme M/T's b&w hitch line-X bed liner mp-8 in dash dvd limo Firestone Air Bags hid lights SB3600 DD SFI
wv/5.9/6.7 is offline   Reply With Quote
Old 10-06-2008, 08:55 PM   #6 (permalink)
WV,
Its set to have the change OHC go off like at 7500 miles dude, I have read that it also figures in how we drive and what kinds of driving, but I personally think that has to be a neat sounding line for a sales guy. The reason I say this, because there is no way that any kind of monituring of the oil with what the oil does in the 6.7 in the OEM state they are in and how the oil looks in just a few hundred miles would they wait for 7500 miles before setting the OHC off to change it LOL...
Old 10-06-2008, 09:05 PM   #7 (permalink)
wv/5.9/6.7's Avatar
Yeah i agree Jeb the oil change indicator don't mean a thing to me. This info is good to know so the overhead is not beeping. Great job
Old 10-06-2008, 09:47 PM   #8 (permalink)
NPloysa's Avatar
Originally Posted by Jeb_H View Post
Here is something you can copy and print and stick in the glove box or in the back of your owners manual...
Not a good idea to put this in there if it's sticky
But thanks, good info!
'08 2500 QC, shortbed, Big Horn, 68RFE 4x4, 3.73s, on-board air, air horns, LED running lights along steps, custom 2.5" lift air ride on the way, stock with DPF delete and EGR unplugged, 300/540.
NPloysa is offline   Reply With Quote
Old 10-06-2008, 10:55 PM   #9 (permalink)
Si vis pacem, para bellum
BroncoHound's Avatar
If it actually does monitor the oil, those with a DPF/EGR delete shouldn't ever see the message again because the oil gets SOOOOOOO much dirtier in the first 500 miles on a stock truck than 5000 miles on an emissions-free truck. I haven't seen mine come on since 15000 miles. I am at slightly over 30000 miles now, have changed the oil every 5000 miles.
'08 QCSB 4WD G56 3.42: 6000k HIDs, HBS Leveled, Carli-valved 5100s, Thuren track bar, SSSSS, 325/70R17 Nitto TGs, Ride Rites, ISSPRO EV2 Boost/EGT, Smarty, GHD, Shaved BlueTec badge
"Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter."
BroncoHound is offline   Reply With Quote
Old 10-10-2008, 12:39 AM   #10 (permalink)
The new 4BT Cummins Prius
mattpopp's Avatar
Disable the Seat Belt Chime
In the owners manual is how to disable the Seat Belt Chime. I do not remember totally off hand but its something like this.
2. Let the Dash Lights Turn Off.
(Heres where I can not remember, its either option "3" or "4", all done within 10 secs after dash lights turn off)
3. Insert Seat Belt and Release; Insert Seat and Release; Insert Seat belt and Release
4. Insert Seat Belt and Release; Insert Seat and Release; Insert Seat belt
5. Turn the ignition switch to the OFF/LOCK position (I think you should here a Chime if you did it correctly).
07 l 6.7 l .75 ton l MC l with stuff on it and a new head gasket
96 l 5.9 l .75 ton l EC l with not much on it
Be VERY skeptical of information you read on the internet.
mattpopp is offline   Reply With Quote
Old 10-11-2008, 03:45 PM   #11 (permalink)
Screw the tree huggers
GH4AU's Avatar
It's option 4 that you do. Leave the seat belt connected on the third insert then turn off the ignition.
08 2500 6.7L Mega Cab Laramie 4X4-8" Rize lift w/Pro Comp 37x13.50 Xtreme A/Ts and 20" Driv Devilslides-Rize traction bars-Iron Bull bumpers-Mag Hytec diff covers-Nathan Airchime train horns-6000K HID headlights-LED tails-Amp Research Power steps-Volant CAI-BADP 5" duals DPF delete-EGR and cooler delete-TS MP8-Airdog 150-Snowperformance stage 3 MPG MAX water/meth-Quadzilla boost fooler-DDP 80 sticks-Wicked stage 2 CP3-WCC intake horn-Shibby boost tube-Isspro EV2 gauges-H&S Black Maxx-toasted tranny
GH4AU is offline   Reply With Quote
Old 10-11-2008, 08:23 PM   #12 (permalink)
The oil change indicator may or may not be monitoring the oil itself, but it is paying attention to driving style. I can run 5000 hwy miles and I'll change the oil long before it tells me to. But, if I spend a couple of weeks only doing stop and go city driving, it will tell me it needs changing after only 2000 - 2500 miles.
08 6.7 2500 Mega, 68RFE, Stock!, Edge Insight (thinks it's a DashHawk!), ELM327 & Perl/TK monitor/data logger. Truck crying for stacks & EGR delete, 2nd turbo smothering.
3rd diesel (06 5.9 killed by tree, 03 5.9 sold, sorely missed!)
BillG is offline   Reply With Quote
