Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 12-09-2008, 10:38 PM   #145 (permalink)
cowpunch's Avatar
Been there, done that with my thermal dynamics. cost of mine free, well the plasma cutter but I've had it a good while.
07 3500 4X4 DRW G56-South Bend Clutch-MP8-Smarty-Industrial Injection super phat shaft 66/80 turbo-Industrial Injection Stage 2 CP3-ARP 425's-ATS pulse flow manifold-DDP 80hp injectors-PPE rail plug-BMK25 Bypass-Isspro EV2 Gauges-Edge Insight-4" TBE 7" Tip-Air Dog DF165-180 Thermostat-Wicked coolant bypass-KMC Rockstars-Debadged
Dynoed 603 hp 1201 ft/lbs
cowpunch is offline   Reply With Quote
Old 12-10-2008, 09:20 AM   #146 (permalink)
Shibbyutman's Avatar
Originally Posted by aaronesq View Post
FWIW - I ended up reusing all my gaskets when deleting the EGR & cooler - but I did buy new gaskets from the local dealer before I started ripping stuff off.
Anyway, all the gaskets are cheap ($2-$4 each) except the rear exhaust manifold gasket....dang thing was like $26!!!
right, that is the expensive one that is included in my kits all the other ones are cheapies. I did a bulk buy from Cummins on those ones, if anybody needs one I'll sell it to you cheaper than you can get it from the dealer or cummins. There have been a few guys that have had the stock gaskets blow out or have leaks after attempting to reuse them. I feel that new gaskets is just the safe way to go.
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, BD Power 90's, Studs, Springs, Autometers, Dual 7" Black Stacks/rain caps, Banks intercooler, Goerend Full Built Trans, Smarty set to Kill, MP-8, Full DIY CP3 Mod, Rail capped , FASS 150/150, and big line kit.
Shibbyutman is offline   Reply With Quote
Old 12-10-2008, 07:03 PM   #147 (permalink)
I know this may sound crazy and I have read all the posts on unplugging the EGR, but I cannot open any pictures. Is the EGR on the right or left side of the motor?. There is a plug on the right side that sticks out horizontily and then there is one on the right that sticks out upward. Just want to be sure. Thanks for the help.
Mega250008 is offline   Reply With Quote
Old 12-10-2008, 07:41 PM   #148 (permalink)
Si vis pacem, para bellum
BroncoHound's Avatar
The EGR itself sits on top of the intake manifold on the driver's side of the engine. The EGR cooler and servo motor both sit on the exhaust manifold on the passenger's side of the engine.
'08 QCSB 4WD G56 3.42: 6000k HIDs, HBS Leveled, Carli-valved 5100s, Thuren track bar, SSSSS, 325/70R17 Nitto TGs, Ride Rites, ISSPRO EV2 Boost/EGT, Smarty, GHD, Shaved BlueTec badge
"Certainly there is no hunting like the hunting of man and those who have hunted armed men long enough and liked it, never really care for anything else thereafter."
BroncoHound is offline   Reply With Quote
Old 12-10-2008, 07:45 PM   #149 (permalink)
Gotta love that whistle
KBosworth06's Avatar
Sent you a PM
2007 Ram 2500 - 6.7L - Auto - QCSB - 4x4 -Black - Lone Star Edition
Blacked Out lights and emblems || Tint || JL-CDT-Alpine system || 6000K HID
6" Superlift w/ Bilsteins || Dual Shocks || 35" Toyo A/Ts || 20" Pro Comps
http://i250.photobucket.com/albums/g.../Siggy-1-1.jpg
PMT in SRT-10 pillar || MP-8 || AFE MegaCannon (Thanks K2/Keven!) || Quad Boost Fooler || Autometer Boost Gauge || BADP 5" SS TBE || K2 Complete EGR Delete
KBosworth06 is offline   Reply With Quote
Old 12-11-2008, 10:27 AM   #150 (permalink)
Thanks Broncohound and KBosworth06. I thought that was it but without confirmation I didn't want to unplug the wrong thing. Going to unplug today and see what happens.
Thanks again
Old 01-09-2009, 05:48 AM   #151 (permalink)
i lost quite a bit of coolent doing the delete... what is the "special" type to buy?
2007.05 6.7L Gray QCSB BigHorn 4x4, S67 SW#3, AFE CAI, NODPF, NOEGR, NOEGRC, EDGE (only monitoring now), MP8
jarrod is offline   Reply With Quote
Old 01-09-2009, 06:40 AM   #152 (permalink)
well... doesn't look like ill finish... tried everything but can't find my 15mm crows foot to get one of the bolts on the housing... ugghhh
Old 01-09-2009, 08:07 AM   #153 (permalink)
if you have any of those wobble extensions those will work to get that one off, or even a swiveling impact socket. I didn't have to use the crows foot on the ones that I have done. I did try it on the first one, and it ended up being so tight that I almost bent it open anyway. I would keep trying different socket and extension setups until you find one that work. Best of luck.
Old 01-09-2009, 11:15 AM   #154 (permalink)
that 15mm nut closest to the firewall and the engine on the egr cooler housing is the biggest pain in my ***
