Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 10-10-2008, 10:04 PM   #121 (permalink)
operator62's Avatar
I finished my cooler/egr delete just about an hour ago. Everything went fine. The two exhaust nuts holding the cooler on next to the head are definitely a bit of a pain to get to. I actually used a straight wrench and an air hammer with a V shaped chisel on it to break the front one loose. Worked pretty well. At first I left my egr plugged in, but tied up and the truck didn't run right that way. It was basically like the butterfly was opening and closing causing surging and lurching. I thought I was going to have to remove the butterfly, but instead I just unplugged the egr valve and the surging went away and it runs great. Went for a test drive even with some hard pulls to check the throttle response the lowest it dropped to was about 19.4. Mostly getting close to 20.5 though. I did lose a bolt down in the driver's side fender well, but it was just the one that held the crossover pipe in place in the center.
operator62 is offline   Reply With Quote
Old 10-22-2008, 09:11 PM   #122 (permalink)
stone88's Avatar
Can't get the third step to load can anybody tell me what it is
2008 6.7 liter Cummins Quad Cab White Short Box Laramie auto, Banks Ram Air Intake, autometer guages, badp 4" then Magna flow 5", EGR MIA, Edge Juice/Att
stone88 is offline   Reply With Quote
Old 10-22-2008, 10:15 PM   #123 (permalink)
Compcowboy's Avatar
Fixed it, should work now.
691 Hp 1200+ Tq - 2007 6.7 TWIN TURBO DUAL CP3 2500 Bighorn 4x4 6-spd Manual, 64/71/14 over a S400, Airdog 150, ARP Head Studs, TS MP-8, Airbags with Dual Control Air Comp., H&S Delete & Downpipe, What EGR?, Valair Dual Disk, Amsoil Bmk-11 Bypass, 295/70/R17 Toyos on Walker Evans Wheels,6" Aussies & Hushpower Muffler & DiProcol Gauges & 120HP nozzles (Installed!) Thanks to Wally At FTEDiesel!!!!! PMT is gone, Smarty is Gone!, H&S TO THE RESCUE! Black Maxx on the way.
Compcowboy is offline   Reply With Quote
Old 10-23-2008, 10:01 PM   #124 (permalink)
railin 6.7's Avatar
you have videos on youtube?
07.5 6.7l, afe, all deletes, edge unlocked, southbend dd, fass 150, bd intercooler, trail ready bumpers f/r, kore chase, homebrew headache rack...
railin 6.7 is offline   Reply With Quote
Old 10-26-2008, 12:03 PM   #125 (permalink)
DRT086.7's Avatar
Hey can someone post measurements of those plates. I work at cat and we have tons of block off plates that we use on everything and they are all thick Im just trying to figure out what ones to grab before I pull off my cooler. If yall will do this I can tell you a pn just to go get them at cat.
08 6.7 6-spd man Quadcab 4x4 EGR all gone, Shibby Grid Heater+Stage 1 Intake horn, 5" SS TBE, AFE intake tube, Airaid, Edge, Diablo EPP, Pure Performance 4", SBC DD 3600, 35/12.50x18s on Jesse James Lawless8's, Recon cab lights 487hp/972tq
DRT086.7 is offline   Reply With Quote
Old 10-26-2008, 12:27 PM   #126 (permalink)
Rail Drainer
Shibbyutman's Avatar
you can buy the plates right from K2DieselPerformance one of the site sponsers here, comes with new gaskets and specially made plates for this application along with a tube to bypass the coolant passages of the cooler :thumbsup
The new gaskets are really the key here. Some have reused them successfully with RTV, but quite a few guys have had issues with the factory gaskets being blown out or not reusable by the time they are chisled off the manifold.
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, BD Power 90's, Studs, Springs, Autometers, Dual 7" Black Stacks/rain caps, Banks intercooler, Goerend Full Built Trans, Smarty set to Kill, MP-8, Full DIY CP3 Mod, Rail capped, FASS 150/150, and big line kit.
Shibbyutman is online now   Reply With Quote
Old 10-28-2008, 05:46 PM   #127 (permalink)
BIG ISLAND 6.7's Avatar
I have my EGR Tube welded shut and in place with the butterfly flap in horn removed and connecter for butterfly flap unplugged. I am waiting for my DPF Delete and EGR Delete plates. My check motor light is on all the time and gas milage got better but... The RED Light with lighting bolt symbals comes on half of the time and the truck starts running badly.
Codes are:
P0405
P0106
One of the codes reads boost presure rationalty problem.
I can live with the check motor light but this other red light and the way the truck runs after it turns on has got to stop.
Can anyone help me out with my next move.
Thanks,
Jason
BIG ISLAND 6.7 is offline   Reply With Quote
Old 10-28-2008, 05:48 PM   #128 (permalink)
Glacier Diesel Power
Gypsyman's Avatar
Plug the throttle valve connector back in...
'08 Ram 3500, QC, DRW, 4x4, 6.7L, 68RFE, Laramie ~ H&S XRT, Edge Race J/A, B&G "Modified" TCM, Goerend Twin Disc, X-Monitor, ARP 625's at 160, GDP MODS: Air-Boss 67 Grid Delete, Arctic-Heat Grid Reloc Kit, Pro-Gate 38 (open dump), Full Flow EGR/Cooler Delete, Maximizer Big Line Kit, Double-X Ladder Bars, High Output In-Tank Pump Mod in the works...
Richard @ GDP
509-993-4923
Glacier Diesel Power.com
Gypsyman is offline   Reply With Quote
Old 10-28-2008, 05:50 PM   #129 (permalink)
Thanks I will Try it..
Ifinate Power and Design told me to unplug it.
Old 10-28-2008, 05:53 PM   #130 (permalink)
Actually it is the EGR sylinoid on top of the Horn that the tube goes into that I have unplugged, are we still talking about the same plug?
Thanks.
Old 10-28-2008, 11:39 PM   #131 (permalink)
Compcowboy's Avatar
Yes, I have a couple on there. Under Compcowboy
Old 10-29-2008, 10:37 PM   #132 (permalink)
PHSYCO DIESEL CUMMINS
tvalverde's Avatar
just buy the gaskets from the dealer and use them for your measurment thats what i did.:thumbsup
08 MEGA 6.7 4x4 6speed auto, Smarty EGR & COOLER MIA.GDP,Air-boss,GDP Pro-Gate, Banks Ram Air and Super Scoop CAI, Flo-Pro 5" tb MBR exaust tip..Mp8, B&G TCM Tune, & 3.5 Cooler Tube (home brud). HID head light,s (home brud) ..n-fab 6 loop steps.Weather Tech floor mats. Carli performance 2.0 sittin on 35x12.50 Nitto Tera Grapplers & 20X10 Ion Magnums,PDP intake horn on the way.
tvalverde is offline   Reply With Quote
