Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 02-09-2008, 10:39 AM   #25 (permalink)
Derekj's Avatar
What if you only made the 2" round block off plate and took the butterfly out ? Would that not work the same?
2007 3500 Dually 4x4 Laramie 2FH package,6.7L,68RFE, limited slip, 3.73, sunroof, kicker amp and 2x10", 2500 watt inverter,tint, back up camera,B&W G/N, Edge Juice W/attitude all over a MP-8....,BADP'S 5" TBE ,S&B Air,.....
Derekj is offline   Reply With Quote
Old 02-09-2008, 11:43 AM   #26 (permalink)
Torque1500's Avatar
the best part is my EGT hasnt gone over 1200 with the hot juice
2007 Dodge 6.7 DPF delete, Dual 5'' exhaust, custom air intake, EGR delete, juice/attitude
Torque1500 is offline   Reply With Quote
Old 02-09-2008, 12:39 PM   #27 (permalink)
kansascummins's Avatar
what r u seeing for normal driving egt's now?
07 3500 DRW,4*4, 6.7L, 6 speed auto,edge juice with attitude, 4" TBE, EGR delete, aFe mega cannon, 19.5 aluminum wheels, pulls 30' stock trailer around midwest
kansascummins is offline   Reply With Quote
Old 02-09-2008, 02:30 PM   #28 (permalink)
Torque1500's Avatar
EGT holds steady around 650 on the highway. As soon as I park it EGT drops to around 350. I dont even use my turbo timer anymore
Old 02-09-2008, 03:18 PM   #29 (permalink)
MattTN23's Avatar
You would think that in theory that should work the same. You could just remove the butterfly, then you could make 2 of the 2" diameter block off plates and put them on both ends of the egr tube that runs from the exhaust side to the intake side. Like i said you would think that would work the same. and you could just unplug the egr and leave everything looking stock. After all, when someone looks at my motor I want them to know that it is a 6.7.
2007.5 Dodge Ram 3500 4x4 QC Dually Lonestar Edition, Silver with Bucket Seats/ AFE Stage 2 Pro Dry S Air Intake/ Edge Juice w/ Attitude+HOT-UNLOCK/ BADP 4" Downpipe and DPF delete w/ MBRP muffler delete pipe/ EGR delete CODE FREE Thanks to The SMARTY S67ME
MattTN23 is offline   Reply With Quote
Old 02-09-2008, 03:19 PM   #30 (permalink)
Rockwerx's Avatar
I was wondering the same thing.
2008 3500 Laramie QC 4x4 LB DRW 6.7 CTD Auto LSD 3.73 EJA EPP 5" TBE AFE CAI -EGR 3.5" BOOST TUBE AirDog 150 RWX
Most wanted mods: Wild Card Customs Intake Horn,Twins
Rockwerx is offline   Reply With Quote
Old 02-09-2008, 03:22 PM   #31 (permalink)
MattTN23's Avatar
I bet this egr delete will make it blow even more smoke, I mean it should. All that was going through the engine will now be going straight out the exhaust pipe. I am going to try doing the two 2" block off plates on the tube when my badp kit comes in. Hopefully someone will do it before me so i know it works. lol.
Old 02-09-2008, 04:10 PM   #32 (permalink)
Hlntoiz's Avatar
Awesome thread! Must be a sticky!
I would think that eliminating the "bad" air would make a hp difference. now there is much better O2 instead of CO2??
This was done with out an exhaust? or a DPF Delete? Would the filter fill up faster and cause more regens?
2007.5 Quad Cab DRW, 4x4 6.7 Cummins, 4.10 Anti-Spin Diff, 68RFE Trans, EB, Icebox intake,
Want List, 5" badg TBE Code Free DPF Delete, Edge A2 w/Juice.
Hlntoiz is offline   Reply With Quote
Old 02-09-2008, 05:13 PM   #33 (permalink)
Compcowboy's Avatar
My truck has the DPF Delete. You wouldnt be wise in removing this before the DPF. The DPF uses the EGR to help create the heat needed to burn the DPF out. No heat=Plugged DPF=$$$$$
691 Hp 1200+ Tq - 2007 6.7 TWIN TURBO DUAL CP3 2500 Bighorn 4x4 6-spd Manual, 64/71/14 over a S400, Airdog 150, ARP Head Studs, TS MP-8, Airbags with Dual Control Air Comp., H&S Delete & Downpipe, What EGR?, Valair Dual Disk, Amsoil Bmk-11 Bypass, 295/70/R17 Toyos on Walker Evans Wheels,6" Aussies & Hushpower Muffler & DiProcol Gauges & 120HP nozzles (Installed!) Thanks to Wally At FTEDiesel!!!!! PMT is gone, Smarty is Gone!, H&S TO THE RESCUE! Black Maxx on the way.
Compcowboy is offline   Reply With Quote
Old 02-09-2008, 06:08 PM   #34 (permalink)
Torque1500's Avatar
my truck would blow some decent smoke, once I deleted the egr I noticed I wasnt blowing smoke like before. But the egt's are down and it runs great.
Old 02-09-2008, 11:24 PM   #35 (permalink)
its hard to see in the pic, but where is the IAT SENSOR. how thick are the plugs that you guys are using?
535banshee is offline   Reply With Quote
Old 02-09-2008, 11:38 PM   #36 (permalink)
sorry about that, just seen where you said you were using 1/8.
i guess you could leave the tube on and just use two round plugs and remove the butterfly. i am going to remove the tube because my fs-2500 will now fit where it fit on my 5.9 did.
