Enabling PMT Special Functions - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 01-24-2009, 06:14 PM   #1 (permalink)
MuscleHead's Avatar
I thought i would post this up since i keep noticing posts talking about about certain functions not working. Heres a brief walk through on how to turn on any of the functions.
1)Get in vehicle close door and insert key
2)Turn key to run position to power up PMT, DO NOT START VEHICLE.
3)Select Menu
4)Select "Special Functions"
5)Select the option you wish to enable, say we selected "High Idle"
6)All functions should be on enable by default,toggle to disable and then back to enable.
7)Return to Main PMT screen and turn key to off position.
8)Remove key and open door.
9)Now you can start the vehicle and your function should work
07 2500 6.7L TRX4 Offroad,5" Pro-Comp Lift,Dual Stabilizers,37" Nitto Mud Grapplers,18x10 MT Classic Lock,Amp Research Steps,Husky Liners,AFE Mega Cannon II PG7,5" Straight Flo Pro Exhaust,Shibby EGR Delete,PMT w/1017G,MP8,H&S FRV Plug
MuscleHead is offline   Reply With Quote
The Following User Says Thank You to MuscleHead For This Useful Post:
N Dubya (03-02-2010)
Old 01-24-2009, 07:37 PM   #2 (permalink)
Compcowboy's Avatar
Good post musclehead. Are you feeling ok?
Sold - 07.5 6.7 Big Horn with lots of goodies.
FTEDiesel
Compcowboy is offline   Reply With Quote
Old 01-24-2009, 07:41 PM   #3 (permalink)
cowpunch's Avatar
Good post big guy! That'll help alot of guys out.
07 6.7 4x4 dually Dynoed at 696 HP 1356 ft/lbs
In no way stock
cowpunch is offline   Reply With Quote
Old 01-24-2009, 09:02 PM   #4 (permalink)
MuscleHead's Avatar
Feeling just fine
Old 01-24-2009, 09:04 PM   #5 (permalink)
08 Black Cummins's Avatar
so let me get this straight. PMT can enable high idle on all 6.7s?
2010 6.7 Mega Cab Laramie 4x4- Slighty Modified
SOLD08 6.7 Auto QC 4x4-Not so stock
08 Black Cummins is offline   Reply With Quote
Old 01-24-2009, 09:10 PM   #6 (permalink)
MuscleHead's Avatar
As long as it is equipped with an automatic transmission.
GreyGrouper (03-17-2013)
Old 01-24-2009, 09:19 PM   #7 (permalink)
there was a guy in another post who said it wouldn't enable it on his automatic. Do you think it was because he didn't follow step #6?
Old 01-24-2009, 09:28 PM   #8 (permalink)
MuscleHead's Avatar
More than likely he isn't, #6-8 are the key to getting it to work properly.Main reason i made this post to help my fellow PMT bros out
Old 01-24-2009, 10:01 PM   #9 (permalink)
Compcowboy's Avatar
It will work on a manual trans. if you ground out the little green wire under the dash.
FTEDiesel
Old 01-24-2009, 10:26 PM   #10 (permalink)
crodg22's Avatar
went out tonight and enabled mine,thanks musclehead.
2008 Mega Cab 6.7 4X4,auto tran., 20in matte black Moto Metal 957 with Nitto 305/55R/20 terra grapplers, 2in leveling kit,Bushwacker extend-a-fender painted to match truck,spray in bedliner,SMARTY,AFE Stage II with pro dry filter, DIY dpf delete,shibby egr delete
crodg22 is offline   Reply With Quote
Old 01-24-2009, 10:34 PM   #11 (permalink)
clark4131's Avatar
Hot Damn! I've been under the impression you could only get it to work if the dealer had enabled it with the Starscan. I've gone through all sorts of different enabling tries with different sequences and it never worked until now. Maybe I never did it in this particular sequence, or maybe it's the XOP version, but I have manual high idle now. Thanks much MH ...SC
'08 2500 Mega SXT, Smarty 6.7ME, MHP TCM, EDGE Insight, AirDog II-165, BMK-21, S&B Intake, GDP Intake Horn/TV Delete/Fuel Filter Delete, Bilstein 5100's, HBS Level Kit, EGR MIA, Stealth DPF/NOx, Mag-Hytec Tranny & Rear Diff Pans, Carli Trackbar, DSS Steering Brace, RCX Dual Bilstein Stabilizers, Detroit TrueTrac, Fusion Front/Fab Fours Rear Bumpers ...
clark4131 is offline   Reply With Quote
Old 01-24-2009, 11:55 PM   #12 (permalink)
ok, now I want a PMT. I have been thinking of making the switch anyway. If any of you have read some of the other high idle posts I have had a time with my dealer enabling it for me. It still hasn't been enabled. I read the posts about the performance difference difference in the two. I think this may have made my decision for me. This may be a stupid question, but could you use someone else's PMT to enable the high idle and still use the edge or does the PMT VIN lock?
The Following User Says Thank You to 08 Black Cummins For This Useful Post:
DIESELCONVERT (06-29-2012)
