Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 6.7L Tech Articles
6.7L Tech Articles Tech Articles for the 6.7L Dodge Cummins Diesel...NO ADVERTISING
Old 12-16-2008, 06:33 AM   #25 (permalink)
Matt SD,CA's Avatar
Originally Posted by slagburn View Post
I can't find an install manual for the power puck but if it requires shimming the fuel release valve then it will be the same procedure.
Glad y'all like the vid, a first for me and it was difficult talking to nothing but a camera.
Hey Slag.....Well done!!........
When are you going to put it on the rollers??.....
04 Ram 2500 QC Laramie 4x4 6spd..46 psi /1050 egt. A little water/propane..keeping things cool.....Stock he341 turbo/Stock IC/Stock 3.5" down pipe/Stock sticks/Stock paper air filter... and a few tricks...529.56 HP/ 1158.66 tq @ 40 psi,dyno not fully loaded
Matt SD,CA is offline   Reply With Quote
Old 12-16-2008, 10:08 AM   #26 (permalink)
Diesel Poser
slagburn's Avatar
Probably the next roller day that comes along that will pick up RPM on the 6.7L.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21
slagburn is offline   Reply With Quote
Old 12-16-2008, 01:08 PM   #27 (permalink)
-Ross-'s Avatar
Great job!
2008 CTD Mega Cab Laramie 4x4 -
Leveled, 20" Moto Metal 956's, Nitto TG's, AEM Brute Force CAI - Edge, MP-8, "Some other stuff fell off."
-Ross- is offline   Reply With Quote
Old 12-17-2008, 01:20 PM   #28 (permalink)
Jeepstang's Avatar
Nice job!
you would think that the mfr would have those washers replaced with a single machined .0090 piece and just get the part from the dealer and ship them to the customers already modified
i bet that piece would not cost very much and it would save the installer time
I would rather pay a bit more money for something that would be a cleaner install but that is just me..
18,000 all code free miles! with all emissions intact.
2007.5 3500 DRW Megacab 3.73, 68RFE 4x4,
24.8 Miles from Obama
Jeepstang is offline   Reply With Quote
Old 12-17-2008, 01:40 PM   #29 (permalink)
Diesel Poser
slagburn's Avatar
I've been told that the valve is $300+ from Cummins and more from the dealer.
Old 12-17-2008, 01:44 PM   #30 (permalink)
what is the advantage of shimming the valve and is it wise to do this without any other mod
help our government destroy america join an enviromentalist club f**** the epa
7$ dpf delete 07 3500 quad cab 4x4 dually
yjcrawler is offline   Reply With Quote
Old 12-17-2008, 02:14 PM   #31 (permalink)
Diesel Poser
slagburn's Avatar
Without a pressure box (MP8 / Powerpuck) I believe the electronics will back down at ~23k on the rail so shimming doesn't gain anything.
If you're not going to put a pressure box on I wouldn't bother with the shimming process.
Old 12-17-2008, 06:38 PM   #32 (permalink)
Jeepstang's Avatar
Wow!
Ok that explains why they have you do it the way they do. from the pictures I was thinking 20.00 tops
Old 12-17-2008, 07:05 PM   #33 (permalink)
jwhite44's Avatar
So, what's the theory behind a pressure box?
jwhite44 is offline   Reply With Quote
Old 12-17-2008, 10:15 PM   #34 (permalink)
Diesel Poser
slagburn's Avatar
Diesel Performance Specialists
Old 01-09-2009, 09:39 AM   #35 (permalink)
When installing the harness for the fuel pressure sensor has anyone had as much problems putting it on as getting it off? I'm beginning to think it doesn't fit.
hwyroller is offline   Reply With Quote
Old 01-09-2009, 10:03 AM   #36 (permalink)
Diesel Poser
slagburn's Avatar
I heard a few stories about the RP plug not fitting on the sensor, thus far they all wound up with saying that TS doesn't see it as an issue. I suspect that there might be a harness with plug assembly that is very very close to the Dodge plug that is shipping with some of these kits, it seems that TS offers the MP8 for just about every type of diesel out there including some agricultural equipment.
Mine fit perfectly but it was connecting to a Pricol RP gauge plug and not the RP sensor.
