Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-26-2008, 01:34 PM   #25 (permalink)
123buster's Avatar
so your saying that the gvwr is only 2200 lbs or less on a 3/4 ton. i think someone told you wrong
2003 HO, slt, 6 speed, 4x4, QC, short bed, white, sport grill, tow mirrors, bed decals, weather guard tool box , silencer ring mia, 5 inch exhaust, Airdog 150, Smarty 4.2 Beta, dipricol optix guages (pyro, fuel, boost), body guard front & rear replacements, black recon cab lights, smoked head lights, 6k HID low/high beams, sb feramic 3600DD, 6 inch top gunz lift, 17 in black wheels, 37 inch toyo mts, and loving it.
123buster is offline   Reply With Quote
Old 11-26-2008, 01:43 PM   #26 (permalink)
KILO's Avatar
Originally Posted by Madhatter1 View Post
What about the brakes? The most I got out of my 2500's was 80K (highway miles, unloaded). My o5 3500 SRw is now at 167K on original brakes and still have meat on the pads. At this point I could ruin the discs and be happy to buy new discs with my pads. Just good luck or is there a difference in brakes? Thanks.
its just good luck and driving style. the axles and brakes are the same
'07.5 2500 6.7L, G56, 4X4, 37x12.5R17 Goodyear MT/R's, airaid intake, Airgog 150, xrt 175, 5in tbe, egr delete, SB 3250 and Amsoil. Thanks for all the goodies Wally
'09 Jetta TDI for sale, 43MPG @ 80MPH on the highway
KILO is offline   Reply With Quote
Old 11-26-2008, 11:05 PM   #27 (permalink)
tyler_5.9's Avatar
I am in the process of buying an 06 3500 dually for a good price how hard is it to convet it to single rear wheels? I figure i will have to buy a new bed, tires and rims am i missing any thing ar the axels the same between a dually and a single?
Also dont the 3500's have drum brakes on the back where the 2500's have disks
02 2500 4x4, 6sp, 4.10's, 90hp sitcks, airdog 150, 4" strait pipe w/ 5" tip, silencer ring MIA, drop in K&N
tyler_5.9 is offline   Reply With Quote
Old 11-26-2008, 11:21 PM   #28 (permalink)
Smokin'
Hot Stuff's Avatar
The rear axle is different also. The dually axle is wider. You'll need a bed, and SRW axle.
'03 Black 2500 QC/LB 4x4, 6 speed, BHAF, 2" lift, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on filters, Firestone bags
Ohio Coal Roller
Hot Stuff is offline   Reply With Quote
Old 11-28-2008, 06:17 PM   #29 (permalink)
Diesel Poser
slagburn's Avatar
Originally Posted by Trpntj View Post
Here's my leaf springs...
2500 - There is no overload pad mount on my 2500 frame clearly visible on the 3500 frame above.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew stealth shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
When a strong man armed keepeth his palace, his goods are in peace - Luke 11:21
slagburn is offline   Reply With Quote
Old 11-30-2008, 08:31 PM   #30 (permalink)
TrickTruck's Avatar
In the same boat as the OP.
FYI: per a couple door stickers I've snagged off the 'bay the GVW difference is 600#s.
My base decision was the 5.9, but after driving the 6spd auto, I'm considering it as well. But some parts would need to fall off.
The info about not having to pass emissions when over 10k is a hot one. That's a critical piece of information for someone considering the 6.7.
Is this 10k limit nationwide? How can we verify this info?
**edit, well, heck, tried to upload two tiny images and this site refused them. Give me a bit to get them uploaded elsewhere...
2500 door sticker
3500 dually sticker
TrickTruck is offline   Reply With Quote
Old 12-02-2008, 02:36 AM   #31 (permalink)
2500 door sticker
3500 dually sticker
Probably has to do with your local codes. I have a Isuzu cab over diesel with a 14,500 gvw and it has to go thru emissions here. So I expect my 3500 with a 10,100 gvw will be going thru it also.
Specialtylc is offline   Reply With Quote
Old 12-02-2008, 02:49 AM   #32 (permalink)
IDAHO CHAPTER PRESIDENT
kmkdiesel's Avatar
also wasnt cab lights only on 3500 thats what I thought until I bought mine 3500 with out cab lights
-Nic - Idaho Oil Burners President Idaho Chapter 2009 3500 laramie mega cab electric blue, pmt as guages,xrt,mp8,5" tbe with 8" tip, egr (cooler) and dpf delete, afe stage 2, II stage 1 cp3
1996 12v sled puller "dominate this"
kmkdiesel is offline   Reply With Quote
Old 12-03-2008, 02:13 PM   #33 (permalink)
HB69DART's Avatar
Every single 3500 (srw or drw) I've seen has had cab lights. I too thought that was a standard difference between 2500 and 3500.
2007 6.7 4x4 QC DRW, auto - 2" level, Dually Rockstars, Buckstop bumper, MBRP filter-back, S&B CAI, Amsoil bypass, de-badged, Bushwacker flares, Recon, Undercover tonneau
1969 Dodge Dart - 572" wedge
HB69DART is offline   Reply With Quote
Old 12-03-2008, 07:31 PM   #34 (permalink)
CajunCowboyCummins's Avatar
well cab ligts used to be a difference but they have become very popular
07.5 Black 6.7 Cummins ..... 4 Door 4x4 BADP Gen 1 5" TBE, EGR/Cooler delete, B&W gooseneck, Prodigy P3 .. custom made shift knob and much more to come hopefully
CajunCowboyCummins is offline   Reply With Quote
Old 12-03-2008, 07:37 PM   #35 (permalink)
both of the 3500's I had didn't have cab lights
08 laramie mega cab 6.7 some goodies. 07.5 laramie quad cab some things fell off
torquey is offline   Reply With Quote
Old 12-04-2008, 12:14 AM   #36 (permalink)
the cab lights were an option when I bought my 07.5 3500
07.5, 6.7l, 3500 SRW Laramie,H&S XRT stage-2 4" exhaust, Aeroturbine 4040XL, Air ride bags with dual cab controller, Hellwig anti-sway bar, Bushwacker fender flares, Progidy brake controller, Toyo 285.70.17 AT's
carpe269 is offline   Reply With Quote
