Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 07-13-2009, 04:01 PM   #133 (permalink)
7492's Avatar
Originally Posted by zigfreed View Post
Heat up your truck good and drain the oil into a bucket. Let the oil cool down over night; drain the oil off the top. When you get to the bottom of the bucket you will see lots of sludge. I think the reason our oil level is rising is due to the soot that is being carried away by the oil. I just noticed this on my last oil change. I also notcied that my 5 gal gerry can that I normaly put used oil is starting to fill with sludge at the bottom of the can. My oil does not smell like diesel. I think the people that oil that smells like diesel need to get there trucks in and get them repaired. The rest of us that have stock trucks just have to live with the rising oil due to soot that is being carried by the oil. I have been debating about installing an oil bypass system to help clean the oil. I think if I do this I will still change the oil on regular schedule.
That means the soot would show in an oil sample....In fact it would be flagged very bad
07 Megacab 2500 4x4 6.7Liter 68RFE 3.70 limited slip . Bone stock and no problems 20 MPG highway easy .. 21.75 best so far.1999 Durango 5.9 Liter 3.92's ALL the options.
Work truck 09 Freightliner M2 33k GVW ISC 260/840 RFO9210B
7492 is offline   Reply With Quote
Old 07-13-2009, 07:47 PM   #134 (permalink)
cabanaman's Avatar
Originally Posted by JR. View Post
If you do the deletes, the oil level will not rise and the engine oil will remain a lot cleaner. Diesel in the crankcase is not good on bearings. The dealership will make up excuses because they can't do anything about it. It's part of the emissions system.
I cuncur, since I did my deletes(at 500 miles) I put 10,000 miles on and there was no rise in oil in that time,just changed it.
2007.5 2500 SLT sport 2wd, Rumble bee hood scoop,6 spd auto,exhaust brake, EGR delete, Gen1 DPF delete, Intake baffle pulled, AX flash, 19mpg city 23mpg highway.
hypertech Econ program B
cabanaman is offline   Reply With Quote
Old 11-19-2009, 10:27 AM   #135 (permalink)
I have an '08 6.7 - have same problem. Filed for refund under NH Lemon Law - in for last repair/fix try at dealer. How did your issue turn out?
Thanks,
Gregg
NHDiesel is offline   Reply With Quote
Old 11-19-2009, 08:07 PM   #136 (permalink)
Didn't read all the older posts, but mine had the same problem of rising oil on the dipstick. Now with 35K miles on it, it has significantly mellowed out. I think it just really needs to break-in to get the rings seated well... unfortunately the oil is still black until I do the deletes.
Patriot 2007.5 Dodge 2500, QC, SLT, 4X4, SB, 6.7 CTD w/EB, 68RFE, 3.73's, posi
Espee is offline   Reply With Quote
Old 11-19-2009, 08:33 PM   #137 (permalink)
mikeshauling's Avatar
OK, i read the first few pages , then skimmed the rest. Heres my question(s) ??? LOL How come this statement kinda got skipped over...... There is an injector or fuel line that injects fuel into the exhaust after the turbo... hahahehe
09 QC 4X2 BIGHORN DRW G56 3:73 INFERNO RED Timberens B&W GN Dipricol Optix ga.(boost,fuel pr. EGT) , CAT 2 mic remote F/F Smarty17S, stock exhaust in tact.
mikeshauling is offline   Reply With Quote
Old 11-19-2009, 09:43 PM   #138 (permalink)
dougibew's Avatar
engine oil over full
maybe if you read the whole thread from start you wouldn't think it was so funny.
07.5, 2500, Reg Cab, 4X4, 6.7, G56, Stock, BA flash, K&N
dougibew is offline   Reply With Quote
Old 11-19-2009, 10:00 PM   #139 (permalink)
OK , just finished the WHOLE THREAD
Its still funny to me.
Old 11-19-2009, 10:11 PM   #140 (permalink)
Originally Posted by Espee View Post
How would fuel get into the oil from regen cycle? My understanding was that the fuel is injected after the turbo into the exhaust from a seperate nozzle. My oil level looks a bit overfull, but I can't detect any fuel odor yet.... Just ticked past 1500 miles so far.
Originally Posted by ddecdoc View Post
the fuel for regen IS injected AFTER the turbo. your oil cannot be overfilled by regen i would be looking at inj o-rings
Have you read the whole thread? These were the posts that i was laughing at, not laughing at the guys that posted them, but at the actual post itself. I just thought that they were funny posts about an injected fuel AFTER the turbo. One guy says that he thinks it is and the other guy says it IS injected AFTER the turbo, It struck me kinda funny that it WAS A FACT because HE said so.
Old 11-19-2009, 10:14 PM   #141 (permalink)
BUT,,,,, whats funnier is>>>>> The total number of your posts are almost as many as both of theirs together. and youre telling me to READ THE WHOLE THREAD.
Old 11-19-2009, 10:17 PM   #142 (permalink)
I must be getting grouchy in my old age, because that post kinda rubbed me wrong. Almost as much as the TITANIUM DRIVE SHAFT thread did ALMOST
TITANIUM I still love that one !!!
Old 11-20-2009, 03:35 PM   #143 (permalink)
7492's Avatar
You read enough...S.O.S..:bdh ::
The Following User Says Thank You to 7492 For This Useful Post:
mikeshauling (11-20-2009)
Old 11-20-2009, 04:25 PM   #144 (permalink)
dougibew's Avatar
mike
[quote=mikeshauling;2258947]I must be getting grouchy in my old age, because that post kinda rubbed me wrong. Almost as much as the TITANIUM DRIVE SHAFT thread did ALMOST
mike; i guess i did poor job of what i was reffering to. i was relating to the whole topic of high oil. i read all the posts as far back as thay go. my point after reading was that it was a serious issue. so i got the wrong meaning from your post. i apologize. absolutely dont want to make any enimies or cause hard fellings.
