Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-20-2009, 07:04 PM   #1 (permalink)
gtbmxdyno's Avatar
bad u joint
I have a question. Have a friend with a 6.7 09. the rear u joint is bad. He said he thought it was held in by a plastic dhal. How do you get the u joint off.
07 5.9 cummins. triple bully dog with crazy larry, AFE stage 2, Banks 3.5 intake manifold, 5 inch straight pipe RSD exhaust, south bend DD3600 clutch. Airdog 2 df-165. Quadzilla boost fooler. Stewart Warner gauges. chrome everything. sitting on 35s with 17s.
gtbmxdyno is offline   Reply With Quote
Old 11-20-2009, 08:00 PM   #2 (permalink)
Joshua Lee's Avatar
They look to be pined in, I was looking at that the other day. I was also amaized they didnt have any greese zirk....Wonderfull Dodge
'07 6.7/g56, 5" TBE 8" tip, MP8, Q-BF 380/680rw
Thanks to James at Rollin Smoke
Im the Texas inspection guy PM me
Joshua Lee is offline   Reply With Quote
Old 11-20-2009, 08:55 PM   #3 (permalink)
my09cummins's Avatar
this is on my truck and i see the pins, just wondering if it,d be easier to heat the shaft to melt the pins or try and just use a u joint press and snap them off
2009 Dodge 2500 Cummins 6.7 liter 6 speed manual, H&S xrt, 5"tbe, s&b intake, 35" nittos, S.B. 3600
my09cummins is offline   Reply With Quote
Old 11-20-2009, 09:12 PM   #4 (permalink)
trx450r's Avatar
you heat it and it will come out it is not just a pin it is all the way around in a grove have to heat
06 maga 6 speed 3500 srw flame red ,billstein shocks,firestone airbags icebox cool tube s@b filter smoked recon cab lights isspro fuel press rail press boost and egt cat gone OHIO COAL ROLLERS
trx450r is offline   Reply With Quote
Old 11-20-2009, 11:32 PM   #5 (permalink)
gtbmxdyno's Avatar
let me know when u do it travis.
Old 11-21-2009, 10:12 PM   #6 (permalink)
Cummins
crackercwboy's Avatar
x2..............
2007.5 Dodge 3500 4x4 megacab dually, auto, SMARTY,RSD 5" exhaust
crackercwboy is offline   Reply With Quote
Old 11-21-2009, 10:18 PM   #7 (permalink)
cummins67L's Avatar
TRX450r
Is right on the money,,,,,
When you heat it,, it will stink........
cummins67L is offline   Reply With Quote
Old 11-21-2009, 10:40 PM   #8 (permalink)
West Virginia Chapter VP
THEBIGJOB's Avatar
Good Luck! I have changed one of these and it is a real pain. I have also taken one to a driveline shop (money WELL spent). Spicer Makes a joint that will fit nicely that is greasable I'm sure someone will chime in with part numbers
07 2500 QCSB
Some Air, Some Fuel, Some Purdy Stuff, Some Hidden Stuff, and a Smarty Do Dad That They Say is TNT
THEBIGJOB is offline   Reply With Quote
Old 11-22-2009, 10:17 PM   #9 (permalink)
Well that'd be nice if i could find one that was greaseable, this one only lasted me 8 months but i have put almost 40k on it, and talkin to some local 6.7 owners its not very rare for them to go out that early
Old 11-22-2009, 10:25 PM   #10 (permalink)
Oh by the way its the where the rear drive shaft connects to the rear end, if anyone has any info on where i can get a non oe one
Old 11-23-2009, 07:14 AM   #11 (permalink)
Joshua Lee's Avatar
ftworth gear and axle for texas guys
inland truck parts for some other states
The Following User Says Thank You to Joshua Lee For This Useful Post:
my09cummins (11-23-2009)
Old 11-23-2009, 11:31 AM   #12 (permalink)
Thanks, the guy from inland says spicer doesnt make one yet, so im gonna have to go oe
