| 6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING |
2009 6.7 EGT's What is everyone seeing towing and empty
I just installed my Edge Insight gauges with the pyro and boy am I glad I did. My old 5.9 temps rarely ever got above 900 degrees. My new 6.7 I am seeing 1200-1300 at 65 MPH on highway in a head wind unloaded. According to the Edge, Regen was not running at the time. I am scared to death to see what it will read when towing my 15k trailer. What are normal EGT's on this motor loaded and unloaded? and what are high EGT's on this motor? The pyro I will be installing for the turbo temp monitor is post turbo approx. 2-3" behind the turbo on the elbow. Thanks for your help
#2 (permalink) |
Your temps are normal. The 6.7 runs hotter than a 5.9 and I have owned both. When I was on a recent trip I checked the check at the bottom of a steep (8%) grade and went about 1 km. TEMP DEAD START TOP ECT 210 214 TRANS 174 188 EGT 670 1263 BOOST 0 22 Outside temp was 28 C. (very warm temp but not overly hot) Weight 23,000
08 3500 dually Laramie QC 4X4 3:73 no mods |
#5 (permalink) |
A few weeks back I thought the same thing 1200-1300 But I just got my 5" SS exhaust on and the Smarty back on sw2 and I see EGTs at 600 800 now I am Happy
2009 3500-Quad-Cab Laramie 6.7 Auto ShortBed Smarty POD-19ME-Edge-Insight-5"SS-Exhaust-EGR Del, ![]() ![]() NAVY FLEET SUPORT WARFIGHTER
#6 (permalink) |
New Guy
![]() Join Date: Dec 2008
I have my thermocouple installed in one of the egr cooler delete plates, Im usually around 550-750 empty. With the gooseneck empty on the back, it got up around 8-900 on acceleration, but then dropped back down around 650 at cruise speed. Trailer is around 8K empty. Its a heavy pig.
2008 Ram 2500 4x4 68rfe, lots of parts fell off! ![]() Big thanks to Keven@K2, RSD, Kens Performance Solutions! ![]() |
#7 (permalink) |
I have hit 1450 pulling my 24ft goose neck loaded with cows,it was a heavy load, and was goin up a long hill. what is the max you want to see? as soon as i saw that it hit that high i back off right away. what is to high?
2007.5 6.7L 2500 quad cab. patriat blue. turbo lined rocker panels, air raid intake, edge w/attitude w/ hot unlock, ranch hand front bumper replacement, dpf delete! |
#8 (permalink) |
![]() Join Date: Oct 2007
The 6.7's will scare the liver out of you when watching the temps LOL... They do in fact get way hot with how they are firing the last injection pulse so late that the exhaust valve is opening before its through, this leads to really hot EGT's... As of to date, I have burned up two of the EGT probes while towing all the time as I do... They look fine on the outside of the probe, but the sensor on the inside is fried... So make no mistake about what you can see here with the 6.7 far as EGT's... The biggy thing that makes this so hard to say just how freakin' hot these motors can get is, it makes a huge difference in what you do far as mods and how your driving the truck...
Khaki-09' Megacab 3500 DRW 4X4;68RFE;3:73's;DPF, EGR & OEM air intake horn all MIA;My own 5" TBE,CoolTube intake w/crankcase revented;Edge-juice w/attitude+Hot;07' intercooler; doubled the OEM Powersteering & Tranny Coolers, Smarty67(ME) Raptor 150 with filter & water seperator. 180 T-stat. Double B&W hitches.ARP Studs. HTT-SS 73/66/13Turbo&Exhaust Manifold.Shaved Head.MHP-TCM |
| The Following User Says Thank You to Jeb_H For This Useful Post: | 07cummins6.7 (11-13-2009) |
#9 (permalink) |
More Power
![]() Join Date: Feb 2008
Great info here thanks guys....................
2007.5 White 3500 6.7CTD 200,00KM 68RSE Auto 3.73, EGR + Cooler /DPF Deletes , Smarty S67ME , Amsoil 15W40 , Amsoil BMK21 bypass filter , Rinoliner , Isspro guages - pillar mount 3 - console mount 2 , Progate Exhaust wastegate |
#10 (permalink) |
How long have you been using smarty? Do you use it on low settings, mainly to clear codes for deletes? I am being nosey because people that have been running the hot setings seem to be having proplems, head gaskets,trans,etc I note by your sig you have 2ooK. I am about to purchase smarty only to clear codes not for added power. Want to get rid of dpf & egr have had sooty oil since day one. Any comments about how it has worked out for you would be appriciated. Thanks. Doug.
07.5, 2500, Reg Cab, 4X4, 6.7, G56, Stock, BA flash, K&N |
#11 (permalink) |
Not to sound stupid but I need some advice, I had an 02 5.4 with a Edge with Att. and it was great. I just bought an 09 Dodge 3500 with a 6.7 and am looking to get more power, better mileage and maintin my warranty, sound familier? I'm sure everybody want this but am hoping to take advantage of all of your experiences. Any suggestions would be appreciated.
#12 (permalink) | ||
More Power
2007.5 White 3500 6.7CTD 200,00KM 68RSE Auto 3.73, EGR + Cooler /DPF Deletes , Smarty S67ME , Amsoil 15W40 , Amsoil BMK21 bypass filter , Rinoliner , Isspro guages - pillar mount 3 - console mount 2 , Progate Exhaust wastegate Last edited by Punisher 67 : 11-15-2009 at 11:47 AM. |
