Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-07-2009, 03:36 PM   #1 (permalink)
mclow's Avatar
07.5 rough Idle
I have noticed lately that my truck is idling a little rougher than it used to. Im running sw5. I changed my fuel filter not too long ago. Its not a horrible vibration but it is noticable a light with it in gear. Anyone had this problem?
07.5 quadcab, 6in lift; 37in tires;5TBE;smarty s76me;
mclow is offline   Reply With Quote
Old 11-07-2009, 03:44 PM   #2 (permalink)
All the time or only when the engine is cold?
2009 2500 6.7 68RFE QuadCab Longbed 4x4 SLT Patriot Blue
Carli | BlackMaxx | 5" TBE
ant.foste is offline   Reply With Quote
Old 11-07-2009, 03:54 PM   #3 (permalink)
mclow's Avatar
seems to be all the time.
Old 11-07-2009, 05:55 PM   #4 (permalink)
Joshua Lee's Avatar
Yup engine is breaking in.. Check and clean all sensors, check boots on the intake and look for stuff thats not correct. Other than that its a diesel so its not gona idle like a porche.
'07 6.7L Cummins, 6 speed Manual, 5" TBE
Joshua Lee is offline   Reply With Quote
Old 11-07-2009, 06:45 PM   #5 (permalink)
About a year ago my 6.7 starting idling a little rougher than normal and I poured 8 oz of Diesel Kleen in the tank at next fillup and the difference was noticeable. You might try that...certainly can't hurt.
2007.5 RAM 3500/6.7/G56/4WD/SB/SRW/mineral gray/Big Horn edition/bone stock
mr. ed is offline   Reply With Quote
The Following User Says Thank You to mr. ed For This Useful Post:
mclow (11-08-2009)
Old 11-07-2009, 10:21 PM   #6 (permalink)
Glacier Diesel Power
Gypsyman's Avatar
I've noticed slightly more idle vibration in SW5 on the shop truck. Might be a bit of timing difference in that software level.
'08 Ram 3500, QC, DRW, 4x4, 6.7L, 68RFE, Laramie, GDP Deletes, Smarty S67-ME, MHP "Modified" TCM, Edge Insight, X-Monitor, DPP Cool Hose, GDP MK-2+ Filter Kit, GDP Double-X Ladder Bars, lot's more...
Richard @ GDP
509-993-4923
www.glacierdieselpower.com
Gypsyman is offline   Reply With Quote
The Following User Says Thank You to Gypsyman For This Useful Post:
mclow (11-08-2009)
