Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-06-2009, 04:47 PM   #1 (permalink)
dissapointed in smoke switch.
ok yall, got my smoke switch wired up with a 1 watt 100 ohm resistor and 2 10 ohm resistors. The truck is a 6 speed and the only time I get ANY smoke is 1st, 2nd and 3rd gear running thru em. and I got a little puff when I step on it at idle. did i do something wrong??? or is this just as good as it gets?
2008 3500 black single cab dually: 4" turbo back, egr and cooler delete. edge with attitude, s&b intake. 35x12.50 cooper stt's with 2" spacers on the rear.
cumminsoperator is offline   Reply With Quote
Old 11-06-2009, 04:58 PM   #2 (permalink)
Allways_Lost's Avatar
Get an XRT if thats all you want is smoke.
07.5 Mega Cab Dually, White, 6.7 Auto, Recon Smoked Out Everything, 5" TBE, XRT 175, EGR Delete/ Cooler Delete, AEM Workhorse Intake, AutoMeter Phantom II Boost, Pyro, Trans Gauges.....
Allways_Lost is offline   Reply With Quote
Old 11-06-2009, 05:09 PM   #3 (permalink)
so the edge is my problem? from the research I have on here it seems that everyone is getting way more smoke than I am?
Let me clear up that I am not out just looking for smoke. There is a right time and place for pouring smoke. It just so happens that alot of people I know are what I call cummins haters. they say cummins is junk, yada yada yada.
Old 11-06-2009, 05:31 PM   #4 (permalink)
well instead of smokin the cummins haters pull them around until they say uncle its not very hard to do
2009 6.7,red, bighorn quad cab 4x4, 5% tint all the way around 50% windshield smarty made parts fall off my truck..wtf?
CUMMINS FIREFIGHTER is offline   Reply With Quote
Old 11-06-2009, 10:25 PM   #5 (permalink)
txag09's Avatar
My truck actually smokes less running the xrt than the smarty, but I don't really care about smoke because its just wasted fuel. Each to his own though.
2007.5 Patriot Blue 3500 6.7L QC, 4X4, trippin gears w/ the 6 speed, 3.73, Smarty, Arson Jr, Valair DD, Airdog 150, 5" TBE, GHD,3.5" intercooler tube, EGR & DPF delete. KM2 255/80R17, 470hp-853 torque with smarty, 493hp-883 torque with XRT
txag09 is offline   Reply With Quote
Old 11-06-2009, 10:48 PM   #6 (permalink)
Mine works great. Im using a 10 watt 100 ohm. Are you lugging it or trying to run through the gears? It works best to flip the switch when boost is as low as possible. I usually shift up two gears and flip the switch while the clutch is in, then clutch out and step on it. The smoke pours out. The lower the rpms the better. Sorry if you already knew all that.
08 2500 6.7L 6 speed qc lb --- leveled, AEM intake, 5"tbe w/6" tip, Smarty 14ME, egr/cooler gone, Code Free!!!!!!!! Custom deer killer
colocummins is offline   Reply With Quote
Old 11-06-2009, 10:51 PM   #7 (permalink)
WyoMike6.7's Avatar
If all you have to worry about is why your truck won't smoke more.... Than I think you are in good shape.
Mike
2008 6.7 quad cab short box - Smarty - 5'' TBE RSD - EGR Blocked - Edge JWA (Used for Gauges) - Banks CAI w/scoop - Recon chrome ion cab lights - 2'' HBS leveling kit - Rolling Big Power R94 20x10 - Toyo Open Country MT 33x12.50 - Eyelids
WyoMike6.7 is offline   Reply With Quote
Old 11-07-2009, 12:55 AM   #8 (permalink)
JWChadwick's Avatar
MP-8 makes it black as coal on demand. crank it up and drop the hammer, you'll see.
2008 3/4 QCSB 6.7 AUTO 4X4 TS MP-8; K&N; BFG T/A 37X12.5-17; AMSOIL; SMARTY 5" RSD straight
JWChadwick is offline   Reply With Quote
Old 11-07-2009, 02:14 AM   #9 (permalink)
WyoMike6.7's Avatar
a quote from patracy... "If you really want your truck to role coal; get an old tire, throw it in the back of your truck and light it on fire..."
Mike
Old 11-07-2009, 02:32 AM   #10 (permalink)
so a smarty with an mp-8 roles coal huh
Old 11-07-2009, 01:56 PM   #11 (permalink)
why all the smartass remarks yall? can a guy not ask a question in here and actually get a little bit of useful info? I simply wanted to know if this is as much smoke as mine can roll as it is or if I did something wrong. guess yall must all be democrats and oboma lovers...
Old 11-07-2009, 02:06 PM   #12 (permalink)
yea smoke is a touchy issue around here, most people are so scared that obama is gna take their truck away that they wont even pee around their trucks. but maybe you did something wrong its hard to see how much smoke your getting without a video but are you trying to get it in park or goin down the road?
