| 6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING |
grid heater help
if some can help me i dont have enought money for a grid heater delete because i bought a bod intake horn and i relized the the grid heater it self is very restrictive to...my question is can u remove the the little bars in the grid right where the intake connect and unplug the postive wire so it dosent generate heat?
08 Larimie 68rfe 4x4 6 inch fab 38 procomp on 20's,CAI,xrt 120, hs tbe, egr goneeeee 7 inch tip 3.5 boost tubes quadzilla, bod intake horn ,shim kit, black on black riddin high Thans to james @ rollinsmokediesel.com
#2 (permalink) |
cummincummincummin,agh!
![]() Join Date: Sep 2009
That is my plan...! Prob gonna do it this weekend
07 Megacab 3500 6.7 Cummins DRW 4x4, 68RFE, Edge Juice W/Att Hot Unlocked, Turbo mod, DPF/CAT/EGR Delete, Hell Bent Steel leveling kit, Still needing a Air Intake!!! "I'm as confused as a baby in a topless bar!" |
#3 (permalink) |
I dont see why not... If there isnt anything blocking the passage then there is no problem... Unless the computer see's its unplugged??
'07 6.7L Cummins, 6 speed Manual, 5" TBE |
#4 (permalink) |
Glacier Diesel Power
![]() Join Date: Dec 2005
You can for sure. It can be a pain though. The bolts are staked and tear up the threads in the grid heater mounting bosses on the way out. If you really want to improve flow I would cut the mounting bosses out too.
'08 Ram 3500, QC, DRW, 4x4, 6.7L, 68RFE, Laramie, GDP Deletes, Smarty S67-ME, MHP "Modified" TCM, Edge Insight, X-Monitor, DPP Cool Hose, GDP MK-2+ Filter Kit, GDP Double-X Ladder Bars, lot's more... Richard @ GDP 509-993-4923 www.glacierdieselpower.com |
#5 (permalink) | |
Should I also keep the power to grid heater here off and will I throw any codes
#6 (permalink) |
No codes that I'm aware of unless it gets really cold. Then you might see one. A few guys here have reported a random code once in a while but I don't see many. I would disconnect the power over on the passenger side of the engine bay right at the relay.
#7 (permalink) | |
I live in south Florida don't got to worry about cold but how many power supplies are there to the grid
#8 (permalink) |
Single lead. Follow it back from the heater to the relay and disconnect it there.
#9 (permalink) |
alright thanks alot
#10 (permalink) |
any one got a pic to help me out cuting out the heating elements in my grid
#11 (permalink) |
you don't want to cut them out, you should pull the whole plate off and remove the screws like Richard mentioned. They are staked in and will be a huge pain to remove, but it is a necessary evil if you are going to attempt to do this mod.
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, BD Power 90's, Studs, Springs, Autometers, Dual 7" Black Stacks/rain caps, Banks intercooler, Goerend Full Built Trans, Smarty set to Kill, MP-8, Full DIY CP3 Mod, Rail capped , FASS 150/150, and big line kit.
#12 (permalink) |
just wondering what would happen if i cut them out
