| 6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING |
How often passive regen takes place?
Currently I have not performed the deletes yet and I drive roughly 100-150 miles a day, pretty heavy foot so my avg. speed is 75-80. Is it normal my truck is going into regen every other day or so?
09 Black megacab 3500 3.73 DRW 6.7l auto. Smarty, dpf mia, S&B dry, Edge for gauges, Shibby stg 2 intake horn, Shibby boost tube, Airdog 2, Shibby Throttle Valve delete, rail plug IN THE MAIL , bod ewg, MHP stg 2, Shibby grid heater delete. |
#2 (permalink) |
are you letting it idle for extended periods of time?
2008 3500 4X4 QC Black Pearlcoat / 6 speed Auto / AFE stage 2 intake / 2" leveling kit / 20" Jesse James Lawless 8/ 305/60/R20 Toyo Open Country A/T / Bushwacker Pocket Flares/ EGR Unplugged |
#3 (permalink) |
Nope I have the turbo timer on the edge set to 3 min when I turn it off other than that always on the go 80% highway driving
#4 (permalink) |
In my case, regens usually happend every other tank full about 500 to 600 miles. I have an insight monitor and I had it set up to tell me when it was in regen. Dont be fooled by desoot/denox they occured every time I started until the truck warmend up. I'm happy to say that I havent had a regen in 34000 miles, and now get 450 miles before hitting the 1/4 tank mark.
08-2500 QC-LWB - 4x4 - 68re, Smarty 67-ME19 SW3 VGT3, ISSpro EV2 boost gauge, Edge Insight |
#5 (permalink) |
This is from the edge notifying me of when the truck starts it's regen.
#6 (permalink) |
mine seems to go into passive regen every other day or so. I've got it set to tell me time in between regens and it usually is around 5-6000 seconds.... Lots of fuel burnt doing that. Just waiting to do the deletes. It's my New Years Resolution.
2008 QC 4x4 SLT Big Horn Mineral Grey, B&W Hitch, Spray in Bedliner, 25% tint & 5% ,5" brow, S&B CAI Edge Insight, WAS Stock
#7 (permalink) |
ok that seems to be about right
#8 (permalink) |
![]() Join Date: Sep 2009
I have been watching regens. Last tank of fuel I got a regen at 178 miles, and another at 320 miles. Did not get the second complete. Filled tank and now got a regen this morning at 78 miles. I have to get this junk off my truck. Burning fuel to do nothing is insane.
2007 2500 Mega 6.7L Auto 2 WD, Edge JWA, MHP/B&G TCM Mod Tune, Nitto Terra Grappler 285 70 17, AFE Stage 2 Pro Dry, Fixed the DPF, NOX and EGR, much better now, Shibby Stage one intake, BM EWG, Quadzilla Boost Fooler, Autometer 7504/7505/7506 Boost gauges, Maxxbrake controller, XRT 60, (Arctic Grid, Rail Plug, Fuel Boost soon) A wealth of stealth. ![]() Have my house for sale digphoto.net/home |
#9 (permalink) |
Local Rotor Head....
I think you are asking about active regen. Active regen is where it dumps fuel and can be tracked. Passive regen can't be tracked, because it just means the EGT's are high enough from your current load to keep the DPF clean (like in heavy towing)
2005 3500 SRW 4X4 QC LB NV-5600, Jake Brake, Smarty Jr Revo, Airiad MIT, GDP Intake Horn, GDP MK2+ w/ Cat 2um, Baldwin BF1212, Amsoiled, Pricols
#10 (permalink) |
You talkin' to me??
![]() Join Date: Aug 2008
I've seen regens (w/o OHD messages) between 150-300 miles depending on driving habits at the time. Seeing a regen every other day with daily mileages of 175 sounds about right to me. Lot's of towing is supposed to reduce the need for regens due to the high EGT's. I've seen posts of those that get away with that and have fully stock trucks. I've also seen heavy haulers gum up turbos & exhaust. Best thing is to learn what works for you, your truck and your driving habits.
Tom 2008 QC-LB,2500,4X4,White/Kaki,Big-Horn,3.73 Auto,315/70/17 tires, MyGig Nav unit, K&N Air Filter, no baffle,DPF quit working , Smarty & PMT, Mag-Hytec Pan & Diff covers.Toms smarty Journal - UPDATES on Page 1 ..... DIY Deletes How-To
#11 (permalink) |
Before the deletes I made a 2600 mile round trip out to Montana. Every 200 miles or so the my Edge insight would start flashing regen. It's not been over 10k since I wasted fuel
2007 6.7, QCSB, 4x4,68RFE, 3:73, Insight, Amsoil bypass, 35x12.50x17 DC FCII on Stock Rims, Smarty 18ME, 5"TBE, Smoke Switch, B&G Modified Tune, Baffle gone, Prodigy Brake Controller, Diamond Back ATV bed cover http://www.rollinsmokediesel.com/ |
#12 (permalink) |
How do you know when your truck goes into the regen mode? Does it say so on the overhead monitor? I have about 4,500 miles on my '09 & as far as I know it has never regenerated. Thanks, Wayne
'09 Dodge 2500 4x4 Quad Cab (build date 4/09), 6.7L, G56 Trans, EGR unpluged at 500 miles, Frantz By-Pass Oil Filter, Edge Insight, Opti-Lude XPD, B&W Hitch, Fumoto Valve Fuel Filter Conversion, Wolverine oil pan heater, Isspro Perfomax Guages. |
