Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-04-2009, 05:12 PM   #1 (permalink)
Runs like crap what is wrong??
My truck has been running with my current set up for over 40k miles and here recently it has started acting weird. At first it started to miss every once in a while and I just thought it was because it was cold. Now it has become to where its smoking like a freight train and has no power at all hardly! If you rev it up it pops like my old 12v does on cold start up. The only other thing I noticed is the exhaust brake quit working. Anyone else had this problem?? Or know what it is?? I did change the fuel filter and it didnt help
2007 6.7 Dually, 6 Speed man, Edge juice with attitude, Dpf delete, airraid intake
WouldRatherbeCummin is offline   Reply With Quote
Old 11-04-2009, 07:02 PM   #2 (permalink)
i have pretty much the same things on my truck my truck is also acting up does it sound like a flapper hitting something under the hood ive noticed that if i use my e brake it seems 2 be worse
ducks an diesels is offline   Reply With Quote
Old 11-04-2009, 10:34 PM   #3 (permalink)
seanth468's Avatar
Try cleaning your map sensor.
07.5 6.7 Auto SRW SWB QC 4x4 White Lonestar Edition leveled B&W,S&B,DashHawk,4" TBE, and Smarty S-67 14ME Thanks to RSD
seanth468 is offline   Reply With Quote
Old 11-04-2009, 10:37 PM   #4 (permalink)
Blue Freak!
MATTIAC's Avatar
no codes poppin up
08 Elect Blue 6.7 Mega. 3500. Sunroof. Leather.VES. 6" BDS Lift. 37x13.50-20 Toyo OC M/T on Eagle 064B wheels. B/W Pocket Flares. ProFlo 5" TBE w/ 6" Tip. H&S Black Maxx. S&B CAI. AMSOIL. Starter/Alarm. 6000k HID HI/LOW & Fogs. Kenwood DNX9140. 2x Pioneer Series Pro Subs Pwrd by a JL 500/1 v2. Autometer Triple Pillar w/ Boost & Rail Pressure.
MATTIAC is offline   Reply With Quote
Old 11-04-2009, 10:53 PM   #5 (permalink)
cumminsdieselfreak's Avatar
Do you spray any kind of cleaner in it?
2007 Dodge 2500 Quad Cab 4x4 5.9 Southbend DD Smarty Sr w/ TNT Edge Juice & Attitude ATS Intake Manifold Cold Air Kit 4" Straight Exhaust to a 8" Chrome Tip 2" Leveling Kit 35" Goodyears 5%Over20% Window Tint w/ Tinted Windshield
cumminsdieselfreak is offline   Reply With Quote
Old 11-04-2009, 10:58 PM   #6 (permalink)
seanth468's Avatar
Mass airflow cleaner works good. I always use non-clorinated brake cleaner.
Old 11-10-2009, 12:45 AM   #7 (permalink)
took it to local diesel shop they said i got a bad turbo. Tradin it in tomorrow for a H2 had enough!
Old 11-10-2009, 03:57 PM   #8 (permalink)
The new 4BT Cummins Prius
mattpopp's Avatar
So you are getting a 3/4 ton Chevy Gas Suburban instead. I don't see how that fixes the problem??
07 l 6.7 l .75 ton l MC l with stuff on it and a new head gasket
96 l 5.9 l .75 ton l EC l with not much on it
Be VERY skeptical of information you read on the internet.
mattpopp is offline   Reply With Quote
Old 11-10-2009, 09:51 PM   #9 (permalink)
Glacier Diesel Power
Gypsyman's Avatar
I don't see EGR delete in your signature?
'08 Ram 3500, QC, DRW, 4x4, 6.7L, 68RFE, Laramie, GDP Deletes, Smarty S67-ME, MHP "Modified" TCM, Edge Insight, X-Monitor, DPP Cool Hose, GDP MK-2+ Filter Kit, GDP Double-X Ladder Bars, lot's more...
Richard @ GDP
509-993-4923
www.glacierdieselpower.com
Gypsyman is offline   Reply With Quote
Old 11-14-2009, 09:04 PM   #10 (permalink)
havent traded it yet!! No egr delete you are right! Do I have to replace the turbo with one thats a variable vein?? Because the problem with the stock holset is the veins keep geting stuck
Old 11-14-2009, 09:34 PM   #11 (permalink)
Topcat's Avatar
Smile
Why are you not taking it to your dealership.It could be very minor,and if it is turbo related doesn't it fall under extended warrenty as far also as emission related or engine related.
Topcat is offline   Reply With Quote
Old 11-14-2009, 10:54 PM   #12 (permalink)
Rhyno's Avatar
I have had things like this happen. After looking around, I found exhaust gasses leaking through the gasket at the back of the exhaust manifold. The gasket connected the EGR to the Exhaust manifold. After tightening the two nuts ( I think they were 15mm) the problems were fixed. Check it out.
I hope this helps...
-Rhyno
"EarthFirst..We'll Pipeline The Rest Of The Planets Later." '08Quad,C&C,6.7L,G56,Electronic4-by-knob(?!),4.10's&limited-slip,AmsoilBypassFltr,FirestoneAirBags,CstmWeldBed ,'07Pipeliner200D,50"DonaldsonMuff.Home-madeCAI.Amsoil Air Filter,PMT
Rhyno is offline   Reply With Quote
