Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-04-2009, 04:10 PM   #1 (permalink)
that damn cummins's Avatar
grid heater
is there anyway to clean the grid heater without taking it off and is it worth it
08 Larimie 68rfe 4x4 6 inch fab 38 procomp on 20's,CAI,xrt 120, hs tbe, egr goneeeee 7 inch tip 3.5 boost tubes quadzilla, bod intake horn ,shim kit, black on black riddin highThans to james @ rollinsmokediesel.com
that damn cummins is offline   Reply With Quote
Old 11-04-2009, 05:16 PM   #2 (permalink)
cummincummincummin,agh!
usmc_butler's Avatar
Yes and Yes! Best thing I ever did.....
07 Megacab 3500 6.7 Cummins DRW 4x4, 68RFE, Edge Juice W/Att Hot Unlocked, Turbo mod, DPF/CAT/EGR Delete, Hell Bent Steel leveling kit, Still needing a Air Intake!!!
"I'm as confused as a baby in a topless bar!"
usmc_butler is offline   Reply With Quote
Old 11-04-2009, 05:18 PM   #3 (permalink)
Any tips on how to clean or pics
Old 11-04-2009, 05:51 PM   #4 (permalink)
kozy's Avatar
'07.5 6.7L 3500 Quad Cab SLT. 295/70 Open Country M/T's, Edge w/attitude, Quad boost fooler, True Flow XDI, Levelled by HBS, Deleted by me.
kozy is offline   Reply With Quote
Old 11-04-2009, 06:00 PM   #5 (permalink)
could you just remove the grid heater and leave it out?
cumminsoperator is offline   Reply With Quote
Old 11-04-2009, 06:03 PM   #6 (permalink)
kozy's Avatar
You can do a grid heater delete but I'd never get my truck warmed up (or started) without it in the winter unless I put in an espar or webasto heater....but thats $$$ I don't have. My truck doesn't like -30 as it is. Without the grid heater?....ugh.
Old 11-04-2009, 06:22 PM   #7 (permalink)
-30? Wassat?
2009 SLT QC SRW 4x4 • 6-speed-auto • 3.73 gears • 285 BFG-AT tires • All Stock
SouthernBoy is offline   Reply With Quote
Old 11-04-2009, 06:23 PM   #8 (permalink)
Take the 6 bolts out of the intake horn and there is the grid heater... I live in Oklahoma so winters aren't so bad so I am eventually going to take the grid out but if you live north your truck might have problems warming up. When I cleaned mine I used a screw driver and shop vac to get the clumps out then rag and brake cleaner... There is a thread on here someware ill find that shows a complete removal and reinstall of a new grid heater delete... I also found a pic of mine when I removed the intake horn
Old 11-04-2009, 06:24 PM   #9 (permalink)
Tom Diesel's Avatar
How bout a little more info? Like what did you use to clean it?
thanks
07 6.7l 2500 Mega 4X4 auto, 3.73, EAGLE 114 CHROME, 305/55/20 Nitto A/T, De-badged, SMARTY, Volant PowerCore, 5" Magna Flow TBE, V-TEC
Tom Diesel is offline   Reply With Quote
Old 11-04-2009, 06:29 PM   #10 (permalink)
Shibby/K2 Grid Heater Delete Install Guide
Here is the page link the the full delete and a pict of mine (Before cleaning!!!)
Just so you know you DO NOT have to remove any fuel lines from the CP3, rail or injectors....
Old 11-05-2009, 10:35 AM   #11 (permalink)
I'd Also Like to know cause there is no way i'm deleting mine. -40 is a little to chilly to start without it.
2008 2500 Quad Cab Laramie
hgl800 is offline   Reply With Quote
Old 11-05-2009, 10:38 AM   #12 (permalink)
-40?
This Texas boy couldnt even begin to imagine that kinda cold. If we get a few nights at 28f each winter we consider that a cold night.
You northern frozen folks are tougher than me! I wouldnt last a week and move back south.
