Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 11-04-2009, 11:42 AM   #1 (permalink)
kozy's Avatar
Transmission drain plug install.
I'm doing the first fluid change on the auto in a couple weeks and I ordered a magnet and drain plug from Geno's when I got the filters.
I'd like to carefully drill a small hole in the pan (where I plan to put the new drain plug) BEFORE I drop it to drain some fluid and hopefully prevent a god awful mess.
Question is, where in the lowest part of the pan should the drain go? Are there any internals that hang low in the pan that the new plug and magnet might interfere with? Anyone got a pic or measurement?
Oh, I'm sure this is probably in a sticky somewhere but how much fluid does the 68RFE hold?
'07.5 6.7L 3500 Quad Cab SLT. 295/70 Open Country M/T's, Edge w/attitude, Quad boost fooler, True Flow XDI, Levelled by HBS, Deleted by me.
kozy is offline   Reply With Quote
Old 11-04-2009, 12:30 PM   #2 (permalink)
For a good time- Smarty
dad2bike's Avatar
I would NOT in any way drill the pan while it is on. If the bit catches the consequences are really really bad. Take the few minutes and drain the pan in the conventional way. Use some patience and there is little mess. A large pan helps too.
The mess you get when that drill bit punches thru... Well, can you have somebody around with a camera, if you do drill????
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 11-04-2009, 12:36 PM   #3 (permalink)
AsphaltCowboy's Avatar
Take a plastic trash can lid and cut a 1" square hole in the middle of it and set it over your drain pan. This will give you enough surface area to catch most all of the fluid without the mess.
09 2500 QC 6.7L 68RFE Auto. 4:10, 2.5" HBS Leveling Kit, 1.5"-Add A-Leaf,17x9 Moto Metal Wheels, 35x12.50R17 Procomp Xterrain, Bushwacker Pocket Flares
AsphaltCowboy is offline   Reply With Quote
Old 11-04-2009, 01:52 PM   #4 (permalink)
kozy's Avatar
I'm only talking an 1/8" hole and then leave it to drain for a while. If it were a bigger bit I'd be worried about it catching like they always do when going through something thin. I guess I could use the trash can lid trick. So what about location? Does anyone have any ideas as to where to put the new drain? Or are you all just more concerned with seeing me with a face full of ATF?
Old 11-04-2009, 03:45 PM   #5 (permalink)
-lenny-'s Avatar
While the face full of ATF would be pretty darn funny, I would not feel good about drilling a hole in the pan while it is still on the truck. There is not a whole lot of space there. It doesn't make a huge mess when you take the pan off, you just need to be ready to catch the fluid. Once the pan is off the truck, I would think the bottom rear would be the best place for the plug. Just my thoughts...
08 MC 3500 68RFE
Mostly Stock
-lenny- is offline   Reply With Quote
Old 11-04-2009, 03:59 PM   #6 (permalink)
tkhan's Avatar
I would put a small level on the bottom and see which way the fluid will flow where you plan to park your truck on the driveway. You could drill a hole, it is very unliley that you are going to damage anything. Just be gingerly, go slow and use a good sharp bit. But beware, the oil will not only run down but drip off sideways across the bottom of the pan.
I did not bother doing this, I just got a PML aluminum pan that has a side magnetic drain plug. Holds 4 more quarts and has cooling fins to help cool the oil down. Towing my 8000 trailer at 75 mph the temps never broke 161 degrees, when it was 90 degrees outside.
08-2500 QC-LWB - 4x4 - 68re, Smarty 67-ME, MP-8, ISSpro EV2 boost gauge, Edge Insight
tkhan is offline   Reply With Quote
Old 11-04-2009, 04:22 PM   #7 (permalink)
kozy's Avatar
Thanks for the input, I figured there probably isn't alot of clearance between the pan and internals hence my concern with where to mount the drain. I've thought up a way to mount my large catch pan to my floor jack so I can jack it up close to the trans. and minimize the risk of making a huge bloody mess. I'll do that and then determine where to put the magnet and drain after the pan is cleaned up.
I searched and found mention of 16 qts. of fluid for this trans. Is that right? And how much can I expect to actually get out/replace if I can't drain anything out of the TC? Lastly, is there a reusable gasket on the oem pan or do I have to RTV it?
Thanks for all the input, appreciate it.
Old 11-04-2009, 05:19 PM   #8 (permalink)
tkhan's Avatar
I I added 13 quarts with the 4 extra quart pan. They dont use gaskets anymore, just clean and apply RTV.
Old 11-04-2009, 05:50 PM   #9 (permalink)
kozy's Avatar
Right on, thanks.
Old 11-06-2009, 03:14 PM   #10 (permalink)
dont forget your tranny filters while there, also do not overtighten pan bolts or you will strip threads and have leaks, use a torque wrench for good measure.
feduptrucking is offline   Reply With Quote
Old 11-07-2009, 03:00 AM   #11 (permalink)
-lenny-'s Avatar
When I put my Mag Hytec tranny cover on, the instructions said to torque the fasteners to between 7 and 9 foot pounds. I put blue loctite on them, and re torqued after a couple days of driving. No leaks, no problems.
08 MC 3500 68RFE
Mostly Stock
Old 11-07-2009, 12:11 PM   #12 (permalink)
If you do not want to step up for an after market pan, get yourself a B&M drain plug kit or a Mopar replacement drain plug for a 4.0 L Jeep, or a 5.2L or 5.9 L V8 and a nut that fits the plug threads.
If you use the B&M it is a sandwich deal. Just follow the instructions,after removing your oil pan.
I used the second option, removed the oil pan, drilled a hole slightly bigger than the Mopar drain plug and welded the nut to the inside of the pan lined up with the hole, of course. The hole is located near the rear centre of the pan. Install the drain plug from the outside of the pan and you're good to go. I've used this setup on several transmissions for over 20 years.
You could use any bolt and a gasket but the Mopar plug has a built in gasket.
'07 Dodge 2500 QC SLT TRX4 Offroad 4x4 SB 6.7 Auto my DD. '08 Jeep GC Laredo Active QDII 3.0 L Diesel my wife's DD. '65 Dodge Polara 880 Convertible 383 hp Automatic. '98 Jeep ZJ. '98 Jeep XJ.
DWRDodge6.7 is offline   Reply With Quote
