Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 10-14-2009, 08:15 PM   #1 (permalink)
Snaped bolt on rear diff cover
Any you guy have a problem with this. Was swicthing the oil out to synthetic, when replacing the bolts one of the heads snapped off....torqued to spec. 30ft lbs according to doge service manual. Any one know the size of the correct replacement?
flyinfreddie is offline   Reply With Quote
Old 10-14-2009, 08:19 PM   #2 (permalink)
pitman's Avatar
Just take the one directly across from it into oriellys and thell find ya one.
93 4x4 3/4 ton 5_speed CUMMINS. 3.55 gears. Denny t fuel pin. 100 horse injectors. 3200 spring. Power screw tightened to collar. Star wheel and smoke screw tightened. Raptor 100 fuel system. Proud Contributor to Global Warming!!!!!
pitman is online now   Reply With Quote
