Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 09-22-2009, 02:25 PM   #1 (permalink)
libeachbum's Avatar
Big difference in price for fuel filter
Browsing Geno's website for a new fuel filter cause the stealership wants $95 bucks
Looks like Mopar and Fleetguard make a couple different filters with a big difference in price. The older style does not have a replaceable and only costs $28.95
MOPAR MOP5183410AA $28.95
MOPAR MOP5183410AA - FUEL FILTER ('07-'09, 6.7L) DODGE-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
The newer one has a replaceable cartridge and costs MOPAR MOP68061633 $64.95
MOPAR MOP68061633 FUEL FILTER & SHELL ('07-'09, 6.7L) DODGE-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Funny thing is that the replacement filter element costs more than the entire older style filter and housing....what gives? Is there really any significant difference?
2007 2500 QC 6.7, 2" level, 35" bfg's, things have started falling off...literally
BEWARE OF BADP/MAXIMUM PERFORMANCE
libeachbum is offline   Reply With Quote
Old 09-22-2009, 02:36 PM   #2 (permalink)
DodgeLuvr's Avatar
Dont know about the difference but Genos is lower cuz i believe they get directly from Dodge and sell so many of them they can discount.
2008 Laramie "Speed costs money, How fast can you Afford to go?" Performance Shops I Prefer, www.rollinsmokediesel.com / www.k2dieselperformance.com / www.genosgarage.com
DodgeLuvr is offline   Reply With Quote
Old 09-22-2009, 02:46 PM   #3 (permalink)
Yes, there's a big difference. The new style filter is known as "FS2". It's a 2 stage filter, with finer filtration in the 2nd stage than what the older filter has. It's also made of a better material that filters smaller particles but still has adequate flow. I believe the filter media is called "stratopore".
Most people recommend buying a new filter with shell, then buying the replacement filter inserts. The new inserts don't fit in the old shell (not enough room). When it comes to clean fuel, you want the best filter you can get.
2008 Ram 2500 - XLT/XST - 6.7L - 2WD - 3.73 Axle - Mega Cab - 6-Speed Manual - Silver - Rhino Liner
Thob is offline   Reply With Quote
Old 09-22-2009, 02:54 PM   #4 (permalink)
For a good time- Smarty
dad2bike's Avatar
I wish Geno would post up some details on the new filter. Somebody posted someplace, the new filter is 5 micron vs the 7 micron we presently use. I think those are the numbers. Senior moments suck.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 09-22-2009, 03:01 PM   #5 (permalink)
if you have more than one dodge dealer close by it would be worth checking prices....the dealer here in town went from 34 to 79 bucks for the fuel filter....i called another dealer and they still had them for 34 bucks....go figure
2007 Mega Cab 3500 dually 4x4, 6spd, 3.73, afe mega cannon, 5in tbe, egr delete, egr cooler delete, isspro ev2 gauges, Smarty ME
atlas59 is offline   Reply With Quote
Old 09-22-2009, 03:07 PM   #6 (permalink)
OUTLAW CUMMINS DIESEL
Onelongshot's Avatar
Location: Columbia, Illinois ALSO KNOWN AS THE COMMUNIST STATE OF CHICAGO
Yep I called cummins filtration directly and talked to a real nice fellow. Who spoke perfect english because he was an American BTW. He said the upgraded filter had a better filter that would filter to 5 micron. Here is copy of the email response he also sent to me. The FS43257 is a 5 micron @ 98.7% effecient. Thank you for using FleetMaster. Also the drain on the filter has been upgraded and is a lot better. The drain is actually replaceable if the seal ever fails. I hope this helps.
Andy
2008 Dodge Ram 2500 Quad Cab, Short Bed, 4X4 Manual T-Case, 68RFE, 3:73's, Edge Insight, I support. Marco@www.madselectronics.com ..... Bob@www.smartypower.com ...... James@www.rollinsmokediesel.com ....... Latest_Smarty_S67me_update_here_http://madselectronics.com/DownloadS67ME.html
Onelongshot is offline   Reply With Quote
Old 09-22-2009, 03:09 PM   #7 (permalink)
but does the drain work?
Old 09-22-2009, 03:10 PM   #8 (permalink)
It has for me. I do not even have to cycle the key for it to work. The old style you would have to cycle the key the new style you just unscrew the cap and the rubber seal opens and fuel and water if any come out.
Andy
Old 09-22-2009, 03:24 PM   #9 (permalink)
i guess the local dealer here must sell seconds lol cause i have never had any of the drains to work on the 6.7 fuel filters
Old 09-22-2009, 03:27 PM   #10 (permalink)
libeachbum's Avatar
Thanks for the input guys. I'm gonna order the Fleetguard FS43257 for around $50
Old 09-22-2009, 03:29 PM   #11 (permalink)
the old style filter if you unscrew drain 1.5 to 2 turns then turn key to run position so fuel pump turn on it will purge filter. The newer style seems to drain okay without this added step.
Andy
Old 09-22-2009, 07:40 PM   #12 (permalink)
I've got 10000 miles on my truck now. When I change the fuel filter do I have to by another housing for the new filter? I heard you can't by the original filter anymore for these trucks. Is that correct? Thanks
08 Mega cab, 6 speed manual, 2 " leveling kit, 285 70 /17 BFG All Terrains, XRT, 4" Exhaust, EGR Shibby delete kit. A whole other animal now.
Mega250008 is offline   Reply With Quote
