Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Powertrain
6.7L Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine, Transmission, etc...NO ADVERTISING
Old 07-04-2009, 01:19 AM   #1 (permalink)
cyberdiesel's Avatar
Heavy loads w/ 2500 diesel 6.7
I've upgraded to a larger toyhauler, (much larger) and have a question for the gear heads rather than the retired w/ a trailer crowd. I've always been amazed that it's just fine with folks if you build a 900 h.p diesel 2500, but if you speak of tricking out a 2500 to handle some heavy duty **** like towing a heavy load all these guys start quoting dodge safety specs. Basically I 'm wondering what the drivetrain differences are between a non-dually 2500 and a non-dually 3500 cummins 08 model. Are the 6-speed transmissions the same? What about final drive ratios? Please avoid the doom and gloom, as I have an excellent braking system on this new fifth wheel and just would like some advice about what I
can do to help this truck survive a 14000 lb fifth wheel.
Thanks and yes, I know this isnt the trailer section, but I'm looking for tech advice related to this model truck.
08 6.7 egr free toy-hauler-hauler.
cyberdiesel is offline   Reply With Quote
Old 07-04-2009, 01:43 AM   #2 (permalink)
seanth468's Avatar
A 500lb overload leaf spring in the rear is the difference.
07.5 6.7 Auto SRW SWB QC 4x4 White Lonestar Edition leveled B&W,S&B,DashHawk,4" TBE, and Smarty S-67 14ME Thanks to RSD
seanth468 is offline   Reply With Quote
Old 07-04-2009, 02:00 AM   #3 (permalink)
I was hoping to hear that, I've already dealt w/ the rear suspension, and the truck just friggin' cruises with this trailer behind it. Once the smog issues were covered, this 6.7 has turned out to be the absolute BEST work truck and most rock solid tow vehicle I've ever owned.
Thanks Cyberdiesel 6.7 toyhauler-hauler 2500
Old 07-04-2009, 02:39 AM   #4 (permalink)
Rockwerx's Avatar
If you do not want to install an extra leaf a lot of guys install some air bags to help give their truck some more load control.
2008 3500 Laramie QC 4x4 LB DRW 6.7 CTD Auto LSD 3.73 EJA EPP 5" TBE AFE CAI -EGR 3.5" BOOST TUBE AirDog 150 RWX
Most wanted mods: Wild Card Customs Intake Horn,Twins
Rockwerx is offline   Reply With Quote
Old 07-04-2009, 02:58 AM   #5 (permalink)
Question
The airbags are o.k.--, actually a big help. I'm thinking of a 3500 "conversion" for a permanent solution. Either an add-a-leaf or a 3500 suspension via the local salvage yard.
Has anyone simply upgraded their 2500 leafs to 3500 leafs?
Do they fit?
Thanks, cyberdiesel 6.7 toyhauler-hauler
Old 07-04-2009, 07:10 AM   #6 (permalink)
Do they fit?
I too would like to hear from someone that has done this. Does it just bolt right up?
2007.5 Dodge 2500 LWB, 4x4, Lt Kaki, Lonestar edition, fender flares, leveling kit, edge W/Attitude, Stage 1 delete W/EGR unpluged, 18in XD SPY W/Pro Comp Extreame AT, 6spd auto, 373 gears.
Toney198 is offline   Reply With Quote
Old 07-04-2009, 08:59 AM   #7 (permalink)
Smokin'
Hot Stuff's Avatar
The leafs are the same between the 2. The only difference is the OVERLOAD springs. The little "helper springs" on top of the regular leaf pack.
'03 Black 2500 QC/LB 4x4, 6 speed, BHAF, 2" lift, black H2's, 35" BFG MT's, B&W turnover, Juice w/ Attitude, 5" str8 pipe, BD lift pump, spin on filters, Firestone bags
Ohio Coal Roller
Hot Stuff is online now   Reply With Quote
Old 07-04-2009, 12:56 PM   #8 (permalink)
seanth468's Avatar
Im pretty sure you need the bump stop that bolts to the side of the frame. Its what the over load spring hits. Look at any 3500 frame to see it
Old 07-04-2009, 03:32 PM   #9 (permalink)
Smokin'
Hot Stuff's Avatar
Yeah, that's part of the overload spring setup.
Ohio Coal Roller
Old 07-06-2009, 06:04 PM   #10 (permalink)
not to turn this in too a air bag vs leaf spring talk, but the air bags are nice because you can ajust them as you need to, I haul a 302 fusion toyhauler and they work very well! firestones install nice and easy dodge 2500
stock 2500 slt,auto six speed,4x4,quad short box tows a 35 foot fifthwheel toyhauler
tad490 is offline   Reply With Quote
Old 07-06-2009, 06:25 PM   #11 (permalink)
DodgeLuvr's Avatar
just the heavier springs as stated above!
2008 Laramie "Speed costs money, How fast can you Afford to go?" Performance Shops I Prefer, www.rollinsmokediesel.com / www.k2dieselperformance.com / www.genosgarage.com
DodgeLuvr is offline   Reply With Quote
Old 07-06-2009, 06:27 PM   #12 (permalink)
I have to agree with the airbags! Although mine is a 3500C/C with dual wheels, I have them and love'em! The overload will work, but cost you a little ride comfort unloaded.
2007 Dodge Ram Quad Cab 3500 C/C, 6.7 Cummins, auto, 9'-4" CM Hauler bed, Frontier replacement bumper, XRT w/delete Kit, S&B INTAKE KIT! thanks to K2, H&S this truck is fun to drive now!
nostroker is offline   Reply With Quote
