Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 05-09-2008, 06:39 AM   #13 (permalink)
theicon2u's Avatar
I had a box from HS it was a gen. 2 box. I was having problems with it after about 15k. they just sent me a new box. I think its the new code free box! Not sure though. It plugs into the stock wiring harness and not into the sencors! The sencors are unpluged! I set my edge so it doesnt clear codes on startup and the only code i get is a egr code. no dpf codes. Ive only had the box for 2days.
6.7L Electric Blue 2" Lift 285/70R17 Icon Wheels, 68RFE, Painted Flares, Painted Window Vents, 4" TBE DPF Delete, EGR Delete, Edge Juice/ATT Hot Unlock. Cold Air Intake. Waiting For EFI Live For Cummins!!!! 14.2@98mph 4psi Boosted Launch. @3400 ft.
theicon2u is offline   Reply With Quote
Old 05-09-2008, 07:26 AM   #14 (permalink)
pjesson's Avatar
Well if this is true it is very nice. I don't see any point in the sensors if there is no possibiliy of DPF getting full. The fooler box should just be able to report the "DPF empty" message that the computer wants to hear.
I like the idea of a swap in/out cat/dpf section. You would leave the sensors in the stock pipe sitting in your shed and replace that section with a new piece of pipe and plug in the fooler box. Want to return to stock? Just pop the cat/dpf back in and plug in the wiring. OK it isn't a turbo-back and will have less power...but it solves the problems we are having. The guys who need more power can play more exotic games.
Sounds like a simple solution. I like simple!
2007.5 6.7L 2WD Megacab. Inferno Red - Nerf bars, backup camera, power tailgate lock.
Hopefully: UConnect, foglights. After warrantee maybe homebrew then DPF & EGR delete?
pjesson is offline   Reply With Quote
Old 05-09-2008, 08:47 AM   #15 (permalink)
Originally Posted by Cummins 67 View Post
Do you have auto or man trans?
Manual with 3.73 gears.
2007 Megacab 6.7L 4x4
hatchy is offline   Reply With Quote
Old 05-09-2008, 09:17 AM   #16 (permalink)
Which sensors are unplugged? Assume you still have to have the two O2 sensors in there right? Wonder if their new kits will come without the sensor bungs if they are not necessary.
2007 2500 QC 6.7, 2" level, 35" bfg's, things have started falling off
libeachbum is offline   Reply With Quote
Old 05-09-2008, 09:27 AM   #17 (permalink)
What does cabin drone sound like? At 70 mph is is annoying? I want the 5" with muffler. Do I have to be too worried here? Will 4" solve the problem. I to like the idea of the tbe but pjesson, you might be on to something. I don't race, I just want the damn stuff off.
07.5 6.7L 2500 4X4 Mineral Gray Line-X bedliner, Cooper STT 33X12.5, Walker Evans, Icebox...on order Thuren Suspension. Engine stock for now.
Also a '93 2500 4X4 92K stock...hell of a work truck
wildhorseplains is offline   Reply With Quote
Old 05-09-2008, 10:21 AM   #18 (permalink)
theicon2u's Avatar
The same ones that are tapped are now unplugged. So the O2 sensers are still there.
Old 05-09-2008, 10:54 AM   #19 (permalink)
GeoffGiggy8's Avatar
I want one I want one! Would love to get the new HS box if its not throwing codes!
2008 6.7 Auto Big Horn. AFE Pro Dry Stage 2, Edge Juice W/Attitude, TS Performance MP-8, H&S Performance Black Box 5 in. DIY TBE, HBS Level....More to come
GeoffGiggy8 is offline   Reply With Quote
Old 05-09-2008, 12:18 PM   #20 (permalink)
Rockwerx's Avatar
Does that mean that you unplugged the EGT probes and just left them in the delete pipe? It sounds like you DID get one of the new code free fooler boxes. Good to hear that H&S has started to release their new product!
2008 Ram 3500 Laramie Quad Cab 4x4 LB DRW 6.7 CTD 6Auto 3.73 LSD
15K 5th Wheel Hitch 12K Trailer Hitch
Parts keep falling off my truck...The latest in Blacktec technology added
Rockwerx is offline   Reply With Quote
Old 05-09-2008, 12:34 PM   #21 (permalink)
theicon2u's Avatar
Yeah they are out of the pipe and plugs are in there place.
Old 05-09-2008, 12:51 PM   #22 (permalink)
AdamBOMB_STi's Avatar
Nice! I just sent them an email!
07.5 2500 4x4 6.7 Auto 2" level kit, S&B drop in w/DIY CAI duct, 5" TBE w/6" SS Tip, EGR blocked, PMT, DiabloSport Extreme Power Puck, Black H2's, BFG A/T's
2004.7 Subaru WRX STi
AdamBOMB_STi is offline   Reply With Quote
Old 05-09-2008, 01:02 PM   #23 (permalink)
Jeepstang's Avatar
Do the EGT sensors still get uses? my PMT uses them for EGT readings
it did however come with an extra sensor and the software to use it instead of the oem sensors will be able to read it. This sounds like it would be a really easy swap to take it in for warranty work if you just leave the oem sensors in the DPF system and you can install the aftermarket egt probe into dpf delete pipe.
2007.5 3500 DRW Megacab 3.73, 68RFE 4x4, PMT
Jeepstang is offline   Reply With Quote
Old 05-20-2008, 12:20 PM   #24 (permalink)
Any updates on this code-free box. I called PDI and they said the kit they sell will still throw a soft code. Pretty sure it's still the H&S kit.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
