high idle - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks...NO ADVERTISING
Old 11-22-2007, 10:27 PM   #1 (permalink)
rflanary's Avatar
high idle
How can I get the high idle activated on my 6.7. My parents has it on theirs and we bought them at the same dealership at the same time the only diff is mine is a manual trans.
07 4X4 mega with 37x13.50x20 open country m/ts with 4" lift kit, b&w flip over goose neck, rear air bags 5" TBE :thumbsup
rflanary is offline   Reply With Quote
Old 11-22-2007, 10:31 PM   #2 (permalink)
bucket truck's Avatar
I heard somewhere that it doesn't come activated on the manual tranny trucks.
2001 extra cab 2500 SLT laramie (dark blue over silver) 4x4 S.O. 55 block, 47re, silencer ring/resonator/muffler are MIA, gauges, big bumper up front, B&W turnover ball, 315 buck shots, and Quadzilla XZT+ (thanks DieselNut)
'89 GMC Sierra SLX 1500 4x4 186K 350TBI w/custom 400 tranny
'06 Freightliner Business Class M2 106 tandem w/lockers,30k# winch, and Altec digger/derrick
bucket truck is offline   Reply With Quote
Old 11-22-2007, 10:33 PM   #3 (permalink)
rflanary's Avatar
can it be activated
Old 11-22-2007, 10:36 PM   #4 (permalink)
BRAAAP!!!
SkinInc69's Avatar
Heres a dumb question but how do I get my high idle to work if it even have it? It is a 6 speed auto. My pup has a PTO idle program but I never tried it and thought it might work the same but I have no clue. Let me know what you guys think.
2007.5, 6.7L 2500 4x4 LARAMIE- H&S Performance BLACK MAXX with OverDrive, H&S Maxx Flow intake horn, H&S 4" boost tube, H&S 5" TBE straight piped, ATS Stage 4 68RFE, ATS CoPilot, HTT stainless steel 66/71/16 turbo, HTT stainless steel 3rd gen manifold, ARP 625's, Industrial Injection Stage 2 CP3, FASS 150/150, Snow Performance water methanol injection, Capped rail, AFE Mega Cannon, DiPricol Gauges, 4" Superlift/BDS, BOD CA's, GDP X-Bars, GDP CCV Delete, Bushwacker flares, Mag-Hytec diff covers, 20x12 iON-Forged Terminators, 33x13.5 Mickey Thompson ATZ's, RDX Billet Grill, Line X, 20% Tint, 12,000K HID's. www.hsperformance.com
Old 11-22-2007, 10:45 PM   #5 (permalink)
Dieselguy8599's Avatar
To get the high idle to work you turn on your cruise, hit set and it should idle to 1200 RPMs. You can run it up to 1500 RPMs by hitting the resume/accl button.
I know that on the 5.9 it was something that needed to be turned on whether it was a manual or an automatic.
Autos just need it turned on in the computer and manuals have to have a clutch switch installed. The switch on the clutch grounds to a pin on the ECM. It's a safety thing so when the clutch is pressed it ungrounds and turns the high idle off. On the 5.9 you can do a mod so you don't have to spend $108 for the switch from cummins or $300 from the dealer. You spend $12 and get a tap for the ECM from the cummins dealer. install that tap in pin #22 and then run it to a ground.
Here are a couple of pics. High Idle Pin Mod
This is for the 5.9, but I'm pretty sure I read that it will work for the 6.7 also.
2006 3500 Laramie H - QC ° LWB ° 4x4 ° 3:73 ° G56
AFE Stage 2 ° Silencer Ring - MIA ° MBRP T-304 4" TBE 5" Tip ° CAT Delete ° Smarty SW#5 ° ISSPRO Boost / EGT Gauges ° Quadzilla Boost Fooler ° 295/70/17 Nitto Trail Grapplers
Dieselguy8599 is offline   Reply With Quote
The Following 2 Users Say Thank You to Dieselguy8599 For This Useful Post:
GregG628 (10-07-2009), R_Zachs (02-25-2010)
Old 11-22-2007, 11:02 PM   #6 (permalink)
Yes it works for the 6.7. Good job, Dieselguy8599! I was trying to hunt down the info on the safety switch. Glad you already knew it!
Old 11-22-2007, 11:53 PM   #7 (permalink)
TxFire's Avatar
Do you by chance have any part #'s available for your pin conversion or anything from Cummins?? Any other help would be GREATLY appreciated...as I have the 5.9 with 6-spd manual and would LOVE to get this done ASAP!! Any other instructions, #'s or anything you have would be much appreciated!! Thanks!!!
06 MC 2500 4WD SRW. Muff delete....the silencer ring will end up MIA...custom air intake using a AMSoil filter....more to come!
TxFire is offline   Reply With Quote
Old 11-27-2007, 11:23 AM   #8 (permalink)
After seeing a few different threads about the High Idle I have put together some instructions on doing it the cheaper way. I know for fact that this will work on 06 and 07 5.9 motors and I've heard that it will also work on the 07+ 6.7 motor. I'm not sure about the 05.
Here is what you need to do if you have a manual to save a few bucks.
You have to order a pig tail connector to tap into the ECM connector. You can get it from any Cummins Dealer for $12.72. The part # is 3824810 and it looks like this:
Cummins part #3824810
All you need to do the install on pin #22 is Part #3824810 from your local Cummins dealer, a 10mm wrench to undo the ground right next to the ECM plug, a 4mm alan wrench to undo the ECM conector, a 5 inch piece of black wire, a small size ring terminal, a crimper and a paper clip.
*** You may want to disconnect the Batteries before starting this process ***
Step 1: Undo the ECM connector from the ECM using the 4MM alan wrench. In my pictures (See Link at the bottom of the post) I am looking down from the driver side standing at the driver side headlight. The connector is on the driver side of the motor. If memory serves me, The ECM looks like a rectangle box that is attached to the motor. It doesn't look like it is part of the motor at all.
Step 2: Using the paper clip, Push it through PIN #22 from the engine side to get the little orange rubber plug out. Here is a diagram of the ECM Connector:
Diagram of ECM Connector
Step 3: Remove the 10mm nut from the ground, You'll see the ground right next to the where the connector plugs into the ECM.
Step 4: Connect the Black wire to the cummins part you bought. Connect the ring terminal to the other side.
Step 5: Push the pin on the cummins part into port #22 on ECM wire harness. Should be to the right of a black wire on the connector. Keep pushing till you hear a click and feel the pin seat itself into the connector. Gently pull back on the wire to see if it snapped in.
Step 6: Connect the Ring terminal to the ground.
Step 7: Go to Dealer and have them charge you up the wazoo to enable the software. ( Dealer ended up only charging me $22.00)
If you download my pictures and zoom in you will see exactly which "hole" is PIN #22. Also, see diagram above.
If I can do this anyone can. I had my buddy stand by and watch just to make sure that I wasn't breaking anything. By doing this mod I save myself $108 for the clutch switch from Cummins or $307 for the clutch switch from the dealer. all the clutch switch is, is a ground that when you press in on the clutch it ungrounds and turns off the high idle. It's a safety feature that keeps someone from putting it in gear while it's idling at 1500 RPMs.
Hope this helps!
- Daryl (DG)
High Idle Install Pics
The Following 3 Users Say Thank You to Dieselguy8599 For This Useful Post:
JoeRandall (01-21-2011), TURBO D! (12-20-2010), xTomKx (01-27-2012)
Old 11-27-2007, 11:31 AM   #9 (permalink)
ktmrider16's Avatar
i know on my 6.7 when its cold the high idle comes on by itself.
07.5 6.7L Dodge Cummins 6 speed manual 4x4 quad cab short bed, bright red, Airaid intake, Line X bed liner, muffler delete, 4in DPF Delete to 6" black MBRP stacks, ERG delete and cooler delete, 35x12.5x17 Mickey Thompson MTZs, BLACK MAX, and more mods on the way
ktmrider16 is offline   Reply With Quote
Old 11-27-2007, 11:54 AM   #10 (permalink)
Diesel Poser
slagburn's Avatar
They are referring to the PTO high idle not the cold high idle.
I'm going to bring it up with the dealer when I go in for the G30 on Friday - should be interesting to see what they say and how much of a hassle it will be.
07.5 2500 - 4x4 - faster than a few things slower than many others.
slagburn is offline   Reply With Quote
Old 11-27-2007, 12:00 PM   #11 (permalink)
Shouldn't be to much of a hassle. Just tell them that you want the fast idle or "High Idle" turned on. If they play dumb tell them that the tech can do it with the Starscan! They don't like it when you walk in their and tell them what they can do with their own equipment!
Old 11-27-2007, 07:01 PM   #12 (permalink)
Got My 2010 Dually
Ram3500Dually's Avatar
Most are having a hard time finding it in the Starscan. They moved it from where it was on the 5.9's. Its in the enable/disable features in a different section then where all the other stuff like seat belt chimes and headlight delays are.
2010 Ram 3500 Dually CTD 6.7/68RE/3:42 LSD (
Previous Rams:
1990 CC Dually, 1994 RC LB, 1995 CC SB, 1998 QC Dually,
2000 QC Dually, 2001 QC Off Road, 2003 QC Dually, 2005 QC Dually, 2008 QC Dually
REAL TRUCKS DON'T HAVE SPARK PLUGS
Ram3500Dually is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
