high idle - Page 10 - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 07.5 and Up 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks...NO ADVERTISING
Old 09-18-2009, 06:58 AM   #109 (permalink)
mastercaster's Avatar
Originally Posted by brutus617 View Post
so i just read thru nine pages and couldnt get confirmation that this will work on an 03. anybody know? thanks, good write up awesome
no, it won't work on an '03. you have to ground a pin in the ecm, and for the life of me i can't remember which one right now. try search, and hopefu;;y i'll remember after i my brain wakes up.
2010 3500, Mega Cab, DRW, 4x4, 6.7l auto, DPF delete, egr/egr cooler deletes, H&S MiniMaxx & Overdrive software.
mastercaster is offline   Reply With Quote
Old 09-21-2009, 06:09 PM   #110 (permalink)
brutus617's Avatar
bump?......
"smart"03, sb, qc, 6sp, 4x4, pusher intake, silencer ring mia, torque tube vanes mia, , 50 hp edge tips
brutus617 is online now   Reply With Quote
Old 09-21-2009, 08:40 PM   #111 (permalink)
here you go...it's pin #22 on the ecm. below are instructions
http://www..com/5-9l-cr-bombs-afterm...e-my-6spd.html
Old 09-23-2009, 04:47 PM   #112 (permalink)
JDiehl's Avatar
Anyone have the cummins part# for the clutch safty switch? I want this feature but with the kids bouncing around the cab I better get it.
02, QCSB, Auto, Smarty, Raptor, 1/2 fuel line, Cracked Dash - JDiehl
JDiehl is offline   Reply With Quote
Old 09-23-2009, 04:57 PM   #113 (permalink)
AH64ID's Avatar
Grounding the ECM does essentially the same thing as the clutch safety switch. Neither one keep kids from slamming the shifter into gear, and thats the greatest threat. But really how often do the kids climb around the cab with the engine running?
2005 3500 SRW 4X4 QC LB NV-5600
Garrett GT3782R, Colt Cam, Con-OFE, Smarty Jr, Jake Brake, ARPs, GDP PFI, GDP MK2+ w/ "2um"
AH64ID is offline   Reply With Quote
Old 09-23-2009, 05:10 PM   #114 (permalink)
JDiehl's Avatar
You have a good point AH they are never alone. The wife and I are much more likely to knock it around. I thought maybe also getting the switch would alow me to keep my warranty and have the high idle this winter. I recenly had the truck in the dealer and asked about turning it on. The print out they gave me says it is only avalible for automatic trans.
The run around begins.
Old 09-23-2009, 05:24 PM   #115 (permalink)
AH64ID's Avatar
Yes its only for autos becuase of the safety factor of kicking it into gear... But my dealership enabled mine pre-Smarty.
Old 09-24-2009, 12:42 AM   #116 (permalink)
High Idle ??
This is my first diesel, so please forgive the dumb questions; but why the high idle? Second, the local 4X shop said that I should see some improvement in mileage and power with a DPF back 4inch exhaust. It sounds no different without the muffler (? the last muffler looking thing on the exhaust) I have an 08 crewcab 2500 with Airaid CAI, Bully Dog PMT and AFE exhaust. I want the truck to be optimized. It appears that there are two different 6 speed autos, I have the 68rfe, what are the differences? I have been told that the 68rfe is made by Allison (like what the GM trucks brag about) Thanks for any info, guyd
joelackey is offline   Reply With Quote
Old 09-24-2009, 01:08 AM   #117 (permalink)
Got My 2010 Dually
Ram3500Dually's Avatar
The 68ref is an inhouse Chrysler trans. The other 6 speed auto is in the Cab and Chassis and it is an Aisin. Neither are made by Allison
2010 Ram 3500 Dually CTD 6.7/68RE/3:42 LSD (
Previous Rams:
1990 CC Dually, 1994 RC LB, 1995 CC SB, 1998 QC Dually,
2000 QC Dually, 2001 QC Off Road, 2003 QC Dually, 2005 QC Dually, 2008 QC Dually
REAL TRUCKS DON'T HAVE SPARK PLUGS
Ram3500Dually is offline   Reply With Quote
Old 09-24-2009, 09:48 AM   #118 (permalink)
AH64ID's Avatar
It allows you to manually bump up the idle, which will decrease time to warm up in winter, decrease cool down time when towing (If I am towing and stop somewhere and don't want to shutdown I always go to 1100), makes the a/c more efficient if you stop in the summer for a few minutes; and in really cold weather will increase the combustion temp enough to keep the cylinders from washing from unburnt fuel.
Old 09-24-2009, 10:25 AM   #119 (permalink)
bthanks's Avatar
Ok I posted this somewhere before but cant seem to find it. Anyways for the 6.7 with a man. tranny you have to ground a green wire under the dash ( safty switch is on it for the auto's) anyways you ground that wire then you have to go to the dealer and have them activate it with there computer unless you have a smarty because it activates it automaticly.. anyways here are some pics to better understand the one wire that is chilling out under there by its self. Its easy to find, its up behind and above the clutch pedal kinda in with a bunch of other wires...
And this is how I grounded mine
If you want your truck to be cheap and fast it wont be reliable... If you want your truck to be reliable and cheap it wont be fast... If you want your truck to be fast and reliable it wont be cheap...
bthanks is offline   Reply With Quote
Old 09-28-2009, 12:25 AM   #120 (permalink)
Is it only the dealers that can enable the high idle or can a cummins repair shop do it as well?
06 QC L/B, 6 speed, stock for now
klabbe11 is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
