Go Back   Dodge Cummins Diesel Forum > 6.7 Liter Cummins > 6.7L Performance Parts Discussion
6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel
Old 11-07-2009, 04:19 PM   #1 (permalink)
Perestrelo's Avatar
EGR and Cooler Delete Clarification
Sorry guys I have read all the threads and I am just as confused as I was before on what exactly to do with the EGR part of it for my truck. I know to remove the cooler and block off the exhaust manifold and run a new coolant hose. This is the part that im not sure about do i remove the throttle plate or the gears in the motor? With the Edge Race i just unplug the egr valve and not clear the codes?
Thanks for the help in advance guys.
2007.5 Dodge Ram 2500 QC/SB, 4x4 6.7L, 68RFE.
2" Ready lift leveling kit. Mickey Thompson MTZ 315/70R17. Pro Comp 6001 Wheels. S&B CAI, 4" TBE. Edge Race Juice w/Attitude
Perestrelo is offline   Reply With Quote
Old 11-07-2009, 05:55 PM   #2 (permalink)
BOD
rbmedic75's Avatar
by throttle plate your meaning the butterfly plate inside the inlet end of the Intake horn correct? you can do either but removing the little gear should be fine the plate is spring loaded to the open posistion so taking out the little gear will allow it to stay open and probably a little easier
08 quad SB 6 stick time to:SMARTY 14ME, BOD Intake and EWG. BOD @ http://www.rollinsmokediesel.com/
Parts on the shelf waiting--- Isspro EV2, 6" twin Aussie's, Banks Intercooler, Toyo OC MT 37 13.50 R 17, BOD 90 HP injector Nozzles
rbmedic75 is offline   Reply With Quote
Old 11-07-2009, 05:57 PM   #3 (permalink)
AUTOBOX TRANSFORM!!!
SkinInc69's Avatar
and
Aren't you suppose to be in the shop Buck?
2007.5, 6.7L 2500 4x4 LARAMIE 68RFE- H&S Performance Hot Damn 175 ATT, Industrial Injection Stage 2 CP3, FASS 150/150, H&S 5" TBE straight piped, Snow Performance water methanol injection, Capped fuel rail, EGR & Cooler delete, AFE Mega Cannon, Black Op's Diesel intake horn, 3.5" Shibby boost tube, DiPricol Gauges, 3" BDS lift, Bushwacker flares, 20x12 iON-Forged Terminators, 33x12.5 Nitto Mud Grapplers, RDX Billet Grill, Line X, 20% Tint w/ 9" brow, 10,000K HID Hi/Low, Fogs. www.hsperformance.com
Old 11-07-2009, 06:00 PM   #4 (permalink)
BOD
rbmedic75's Avatar
Cigarette break bud but I am in the shop. Babysitting an itake in the powder oven and cutting out some really BADD A$$ Control Arms man your gonna have to get a set of these things they are sweet
Old 11-07-2009, 08:20 PM   #5 (permalink)
Perestrelo's Avatar
Thanks for the help guys I appreciate it
and yes i meant the butterfly plate.
Old 11-07-2009, 09:05 PM   #6 (permalink)
For a good time- Smarty
dad2bike's Avatar
The butterfly plate or gear are only removed if you have DPF delete AND code clear. I the gear is pulled and the DPF is in place, the regens are no fun at all. Lightning bolt and stumbling.
Tom
2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To
Stealth is the WORD!
dad2bike is offline   Reply With Quote
Old 11-07-2009, 09:09 PM   #7 (permalink)
Perestrelo's Avatar
I have had my DPF deleted for awhile now and my Edge Race just showed up yesterday so it will be installed tomorrow. Then Ill remove the butterfly plate and cooler.
Old 11-07-2009, 09:12 PM   #8 (permalink)
dad2bike's Avatar
Kool.
Buck was referring to this vs the plate removal. Quick and clean.
Butterfly Valve Gear Removal How-To
Tom
Old 11-07-2009, 10:12 PM   #9 (permalink)
Perestrelo's Avatar
I can also remove the servo motor along with the EGR valve correct?
Old 11-07-2009, 10:15 PM   #10 (permalink)
dad2bike's Avatar
Follow these instructions.
MADS Electronics - Smarty - CaTCHER - DisclaimerS-06A
Look in the first post of my journal for many other tips and links.
Tom
Old 11-07-2009, 10:28 PM   #11 (permalink)
Perestrelo's Avatar
Thanks Tom I got er figured out now sorry about all the questions don't really want to mess anything up lol.
Old 11-07-2009, 10:34 PM   #12 (permalink)
dad2bike's Avatar
There is absolutely nothing wrong with asking questions until YOU are satisfied with what you are doing. It took many hours of reading and asking others on this forum before I even unplugged the EGR. After that... well I'm still playing around.
When YOU are comfortable then you will move forward.
Tom
