| 6.7L Performance Parts Discussion Discussion of Performance Parts For the 6.7L Trucks Glacier Diesel |
Edge race and smarty
Anybody running a race j/a stacked with a smarty? Is it even possible? Id like to run smarty for its features in dealing with the deletes but i want to run the edge for its features the smarty don't have like a turbo timer, monitoring, safety back downs, switch power on the fly, etc. Thanks, Mooseman
07 6.7 auto, dpf & egr deletes, Quadzilla boost fooler, race juice attitude |
#2 (permalink) |
Mooseman, I am running the Edge Juice with attitude with my Smarty. I run the Edge on ZERO and leave it on zero and turned the timing to stock timing. Then I installed the Smarty and just used the Edge for the gauges, and Smarty for power, you still get all of the features; gauges, turbo timer etc... I would NOT recommend stacking the Edge Race with the Smarty. Run the Edge for gauges and use the Smarty for the power, but I wouldn't in a million years even think about stacking the two...... That's a no brainer. Mike
2008 6.7 quad cab short box - Smarty - 5'' TBE RSD - EGR Blocked - Edge JWA (Used for Gauges) - Banks CAI w/scoop - Recon chrome ion cab lights - 2'' HBS leveling kit - Rolling Big Power R94 20x10 - Toyo Open Country MT 33x12.50 - Eyelids |
#3 (permalink) | |
07.5, 2500, Reg Cab, 4X4, 6.7, G56, Stock, BA flash, K&N |
#4 (permalink) | |
Mike
#5 (permalink) | |
Maybe switch between the two for fun but never run the two up together. Truck go BOOM.
#6 (permalink) |
Why don't you want to use the Smarty for your power? Just curious... Mike
#7 (permalink) | |
07.5 6.7L 6 Speed man. , lonestar edition edge juice with attitude HOT UNLOCKED , SBC 3250 DD , extreme power puck , badp 1 gen delete ,high idle enable |
| The Following User Says Thank You to Teamropinram85 For This Useful Post: | WyoMike6.7 (11-07-2009) |
#8 (permalink) | |
I like to bump it up for passing or for showin off or turn it down when the wife takes it.
#9 (permalink) |
So let me get this right you basically wanna pay 700 bucks to not have your check engine light on, check codes, and enable high idle....cause thats all smarty is gonna do for you if you dont want to get any power from it.....
2007 Mega Cab 3500 dually 4x4, 6spd, 3.73, afe mega cannon, 5in tbe, egr delete, egr cooler delete, isspro ev2 gauges, Smarty ME |
#10 (permalink) | |
![]() Join Date: Sep 2009
I can just see me telling the lovely wife. "Hey hon, hold on a minute here, I have to reprogram the truck because we just dropped the trailer and want to go tour." (five minutes with Smarty as long as it is warm outside, longer if you have to warm up the truck so the grid heater doesn't pull down the voltage, and twenty minutes with the XRT) Or conversely. "Wait a minute hon, I have to reprogram the truck because we are going to pull the trailer over to that pump out station." With the edge, poke poke poke and three level change. As far as paying for code free, it's worth it to me. And with the Smarty and Stealth deletes, if the gubmint ever decides we all have to get our tailpipes sucked on, I can load the half power.
2007 2500 Mega Cab 6.7L Auto 2 WD Exhaust Brake, Edge Juice with Attitude, MHP/B&G TCM Mod Tune, Nitto Terra Grappler 285 70 17, AFE Stage 2 Pro Dry, Fixed the DPF and NOX which work much better now, Coming soon, Shibby Stage one intake install with EGR fix and EWG too, XRT on 60, Smarty here, A wealth of stealth. Have my house for sale digphoto.net/home |
#11 (permalink) |
For a good time- Smarty
![]() Join Date: Aug 2008
Having the Smarty set to a higher HP has nothing to do with USING the power. YOU have total control of how you press the skinny pedal. I safely run all the way to SW7 and have no issues. I have the HP & smoke, available IF I choose to. Normal driving is just a slight pedal push. The higher the sw setting the less pedal I use. I figure on sw9 I would set a feather on the pedal.
Tom 2008 Quad-Cab,LB, 2500, 6.7L, 4X4, White/Kaki, Big-Horn, 3.73 Auto, AS flash, K&N Air Filter, no baffle, Testing in progress- step 4, Stealth DPF, Smarty sw3 PMT gauges. Mag-Hytec Pan & Diff covers.Toms smarty Journal ....... DIY Deletes How-To Stealth is the WORD!
#12 (permalink) |
So D2B, tow with the trailer and tour without the trailer can be done with max economy for both on one Smarty setting?
